Thread: So I think my engine might be dead.....
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: So I think my engine might be dead.....
    Dec 2014
    Bedford
    42 Post(s)
    These are vertical valves and there's a small chance they are ok as valves that are on angle usually get bent to buggery. If compressions are ok then the repair is possible without cylinder head removal.
    Sent from my SM-G900F using Tapatalk
  2. Re: So I think my engine might be dead.....
    Feb 2017
    London
    He had to drill out wider than the old bolt so it now has a step down bolt, m12 in the head and m10 protruding. Is it possible to get that all welded up and rebored? I think I'd sleep better.
    Also so where do I stand on driving it? Is it a matter of what's done is done or will I be making it worse and this more expensive to repair? I've already done about 50 miles.
  3. Re: So I think my engine might be dead.....
    Dec 2014
    Bedford
    42 Post(s)
    Best thing is stop driving it. Do some home work ring around find someone who knows this engine.
  4. Re: So I think my engine might be dead.....
    Feb 2017
    London
    I'll get the rocker cover taken off tomorrow and see where I'm at after that. I'll post back.
    cheers for the help, at least I've now got a starting point
    0 2 0
  5. Re: So I think my engine might be dead.....
    Dec 2014
    Bedford
    42 Post(s)
    Sounds like a plan.
  6. Re: So I think my engine might be dead.....
    Feb 2017
    London
    So we got the rocker cover off and had a good look.... 1 of the rocker arms looks slightly bent, is not seated like the others and also has a very small amount of up and down play in it unlike the others but nowhere near enough to push it back in.
    Im thinking for the sake of a £50 rocker arm and an hours labour surely it's worth swapping it and seeing what happens or is that completely pointless? Does that mean there's definitely damage to at the very least the valves on that cylinder?? Could the cambelt going only have damaged 1 rocker arm and nothing else? Obviously keep in mind the car has been driven over 50 miles in this condition.
    Again, I just don't want to waste a penny if it's gonna be a rebuild regardless
  7. Re: So I think my engine might be dead.....
    #17
    Dec 2014
    Bedford
    42 Post(s)
    Sounds like a knaffed rocker. Has a built in compensator. From memory they are about £16 each. The fact it drives and turns over by hand would indicate that the valves might be ok. Hard to be sure without a compression test though. Had one once that came in with same problem as you. Tensioner stud failed at 60 mph. We drilled it and tapped it to m10. Run it and had a slight misfire. Compression was all ok. We fitted 16 new rockers and it was perfect.
  1. audi a4 53 reg 3.0 v6 quattro dead engine
    By deadaudi2014 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-10-2014, 11:52 AM
  2. Help - My Engine is knackered (DEAD) 2.0ltr TDI
    By WK5 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-07-2011, 05:05 PM
  3. 2001 a6 1.9tdi turbo dead - damage to engine?
    By needmorstuff in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-07-2010, 10:53 AM
  4. dead spot on throttle + engine workshop
    By bigplum in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-10-2008, 11:41 PM
  5. dead engine
    By jgunn in forum Alhambra
    Last Post: 22-04-2008, 12:52 PM
