Thread: 2016 Tiguan coding required - Midlands
  1. 2016 Tiguan coding required - Midlands
    Dec 2016
    West Midlands
    I have a Cat D 2016 Tiguan (66 reg) that has been repaired but now requires the warning lights on the instrument panel sorting out. Does anyone know someone that would look at this in the Midlands area to do a diagnostic check and complete any electrical / coding work required?
    Darren
  2. Re: 2016 Tiguan coding required - Midlands
    1840 Post(s)
    Did the air bags trigger?
  3. Re: 2016 Tiguan coding required - Midlands
    Dec 2016
    West Midlands
    Yes they did, but have been replaced and the ECU has been cleared. I've been told that the airbag light will remain on until it has been reset.
  4. Re: 2016 Tiguan coding required - Midlands
    1840 Post(s)
    Many mechanics, including me, will not clear the data on an air bag ECU which has been cleared, they are made one time only for a good reason. If the car is involved in another accident and the SRS system fails due to a cleared ECU, the blame could come back at the person who cleared the codes.
  5. 2016 Tiguan coding required - Midlands
    Oct 2015
    GB
    I agree with crashes,
    You need a mechanic that has a vag compatible (vcds etc) that can read the codes and locate the fault to fix issue, once fixed the correct way the light will go out.
    Simply clearing the codes with a scanner or deleting the sensor from the module is a risky position for any mechanic to be in like crasher says...
    Sometimes the fault can be something as simple as a dodgy dirty connector, a simple make clean fix, but without a diagnostic code to pin point the location of the fault it's like finding a needle in the hay stack..
  1. Question New 2016 Tiguan ACC
    By Paul.Day2 in forum Tiguan
    Last Post: 06-10-2016, 08:37 PM
  2. VCDS Coding With Latest Version - Midlands
    By dap1974 in forum VCDS - Users Locations
    Last Post: 17-02-2015, 11:03 PM
  3. New battery, is coding required?
    By gregpot2000 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 15-01-2014, 11:02 PM
  4. Help Coding Required
    By Craig F in forum VCDS - Help Requests
    Last Post: 14-02-2012, 05:30 PM
  5. RNS510 Coding required - South Wales
    By welshpedro in forum VCDS - Help Requests
    Last Post: 29-03-2011, 10:50 PM
