Thread: Audi A3 2.0 tdi oil in fuel
Results 1 to 9 of 9
  1. Audi A3 2.0 tdi oil in fuel
    Feb 2017
    Norfolk
    Hi guys I'm new to this forum would like some information on a tandem pump please, right then I've got an Audi A3 2.0 tdi all injectors and seals have checked there all stable, I changed the fuel filter just before Christmas and the diesel was like a black colour so yesterday decided to check her again and yeah sure enough diesel the same colour also car developed a misfire at high speed Idles rough to and loss of power,, it isn't the turbo had a new one last year,,, any help would be appreciated
    Kind regards Danny
    Also the car isn't making oil,,,
  2. Re: Audi A3 2.0 tdi oil in fuel
    Oct 2015
    GB
    Oil in diesel is a sign of tandem pump seal failure,
    Your need to inspect the seals and parts.
    I think YouTube have some videos so take a look.
    Also oil in fuel will mean fuel in oil so this means that ATM the oil is braking down and pd engines really don't need that, so don't use it until it's sorted because you don't won't any bigger problems....
    Once you solve the issue you then need to do an oil and filter change.
  3. Re: Audi A3 2.0 tdi oil in fuel
    Oct 2015
    GB
    Please explain more regarding " car isn't making any oil"....... do you mean the car has no oil pressure??
  4. Re: Audi A3 2.0 tdi oil in fuel
    Oct 2005
    Pretty sure this isn't anything to do with Home Technology.
    What year is your A3, I'll move this to the relevant A3 section
  5. Re: Audi A3 2.0 tdi oil in fuel
    Feb 2017
    Norfolk
    Hi guys sorry if put this tread in the wrong place as I said I'm new to this forum quick update I've just put a new tandem pump on the car only time will tell yeah oil pressure good thank for your input guys,,, I'll let you all know kind regards Danny
  6. Re: Audi A3 2.0 tdi oil in fuel
    Feb 2017
    Norfolk
    Sorry Sam it's a 2005
  7. Re: Audi A3 2.0 tdi oil in fuel
    Feb 2017
    Norfolk
    Hi gents and lady's a quick update of the Audi A3 2.0 tdi 2005 so you all know the car had a new tandem pump after this was experiencing cold start problems so after a couple of checks the lift pump in the tank has now been changed by myself when removing it noticed there all oil over the old unit so fingers crossed this has sorted the problem kind regards Danny
  8. Re: Audi A3 2.0 tdi oil in fuel
    1840 Post(s)
    It will take a very long time to self clean, we take out the delivery unit, drain the tank, wipe it out and blow the lines out plus new fuel filter.
  9. Re: Audi A3 2.0 tdi oil in fuel
    Feb 2017
    Norfolk
    Morning gent's & lady's right then Audi A3 2.0 tdi started first time this morning so problem has now been sorted �� hope this help people who are experiencing the same trouble as I've had it wasn't a cheap fix but I've been lucky that I can fix these problems myself kind regards Danny
  1. Audi Q7 3.0 tdi v6 oil change and oil capacity
    By Shab2015 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 08-12-2015, 07:30 AM
  2. TDI 140 (BKD) rough idle, cutting out and possible oil in fuel
    By ejfhorne in forum Golf MK5 - 2004 - 2009
    Last Post: 08-05-2013, 01:22 PM
  3. Whats the 'fuel additive' Audi are adding on the cars first oil service?
    By Tuk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-08-2010, 02:14 AM
  4. Oil and Fuel supplements for 2.5 TDi
    By wanstronian in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 25-03-2010, 11:38 PM
  5. Oil in Fuel Filter 2.0 TDI
    By turbodiesel3268 in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2010, 03:42 PM
