Thread: EPC and traction lights came on. Code P2138
Results 1 to 9 of 9
  1. EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    So I've had an intermittent issue of my EPC and traction lights coming on and a slight loss of power/ autobox wanting to stay in lower gears.
    I used my OBD2 reader and there was one single code of P2138 which is throttle/pedal position sensor/switch D/E voltage correlation.
    So likely culprits are throttle position sensor, or crankshaft position sensor from what I've read.
    Thing is, the fault has now gone away and the code is gone too?
    Read more at: P2138 DTC Throttle/Pedal Pos Sensor/Switch D / E Voltage Correlation
    Copyright OBD-Codes.com
    2006 Audi A4 B7 Avant 2.0 TFSI S Line Quattro tiptronic in Phantom Black.
  2. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    Yeah, so this just popped up again. So I guess it needs sorting.
    Anyone any idea, comment, info???
  3. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    So just for fun I've taken my throttle body off and cleaned it.
    It's.
    Now clean, but should it have a gap around it when the flap is closed??
  4. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
  5. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    I've refitted it now as I've got to drive the car to the garage for a new exhaust.
    I'll ask them about it when i go there.
  6. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    Ok. So it's still an issue, but at the moment seems ok.
    Having read up a bit more on this I'm beginning to think that this is some kind of moisture within the ECU that's causing the problem.
    Especially as it rears its head when there's been torrential rain or when I've jet washed the car.
    I'll take the cover off the ECU and check to see if anything is getting in.
  7. Re: EPC and traction lights came on. Code P2138
    Jan 2018
    Glasgow
    Hi I have the same problem just now did you find a solution to this problem ?
  8. Re: EPC and traction lights came on. Code P2138
    Apr 2016
    Manchester
    Quote Originally Posted by Pbking View Post
    Mine was a broken ecu cover. There was loads of water in the ecu box.
    bought a new one and fitted it. No problems since.
    make sure you get the correct one. For example the a4 b7 tfsi is a different shaped lid to the a4 b7 Tdi.
    hope this helps.
  9. Re: EPC and traction lights came on. Code P2138
    Jan 2018
    Glasgow
    Hi thanks I’ll give mine a check and see if it’s been letting water in
  1. Please Help EPC and traction control light comes on and then car goes into limp mode.
    By dontclickonthis in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-01-2017, 03:32 PM
  2. 2.3 V5 Passat Traction Control/EPC lights, MAF Vag Com Code...
    By Vandall in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-09-2010, 02:48 PM
  3. Please Help EPC and traction light then LIMP MODE help anyone?
    By dtwoi in forum Audi A3 - Archive Topics
    Last Post: 01-11-2008, 08:27 AM
  4. EPC and traction control
    By gixxerk4600 in forum Audi A3 - Archive Topics
    Last Post: 22-10-2008, 08:38 AM
  5. epc & traction control warning lights
    By janfab in forum Fabia
    Last Post: 09-08-2007, 10:00 PM
