Thread: Red Battery Light - Engine cut out
  1. Red Battery Light - Engine cut out
    Feb 2017
    Manchester, UK
    Not sure if this is the place to post, but I've just signed up to the forum so I'm new forgive me.
    Last night my car (Audi A1 1.4 TFSI 185ps) started up fine, i got about 200 yards down the road, slowed to almost a stop before pulling out at a junction, i accelerated for another 50 yards or so until the engine had completely cut out, the red battery light was illuminated. I coasted to the side of the road & switched everything off, took the keys out & started the car again & it was fine. I was able to drive home about 3 miles with no problem & have been to work this morning with no issues either.
    I did a bit of googling & the battery light indicates a problem with the alternator but can anyone confirm?
    Any idea what this is a problem with? Should I be worried? Any help would be appreciated.
  2. Re: Red Battery Light - Engine cut out
    Oct 2005
    Welcome to VWAF
    What year is your A1?
    Edit - Ignore that, we've only got the one A1 section - thread moved!
  3. Re: Red Battery Light - Engine cut out
    Feb 2017
    Manchester, UK
    63 reg UK
  4. Re: Red Battery Light - Engine cut out
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    So are you saying the red battery light was lit while you limped along for 50 yards, or it came on once the engine had died? It is normal for it to come on once the engine has stalled but ignition is still on. If it was on while the engine was running then yes, it indicates a charging problem. Can you check alternator out put voltage across battery terminals with engine running, should be around 14.5V, 12.5V with engine off, check for loose battery terminals clamps.
    Could be any number of things why the engine lost power and died. I hate to say it but a full diagnostic scan would be good starting point if you can eliminate the basics.
  1. Engine Management Light, cut out and shaking
    By daveb134 in forum Golf MK6 - 2009 - 2013
    Last Post: 01-11-2012, 06:59 PM
  2. Please Help battery flat so i jumped the car red power steering light on wont come off
    By j1981 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-10-2012, 07:21 PM
  3. Red battery warning light illuminating
    By rhencullen1989 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 28-06-2011, 09:52 PM
  4. Engine Management Light Then Cut Out
    By warptechno in forum Polo - Derby - Lupo - Fox
    Last Post: 19-11-2010, 12:24 PM
  5. polo 1.4x engine cut out/oil light
    By One T in forum Polo - Derby - Lupo - Fox
    Last Post: 23-09-2009, 05:47 AM
