Thread: A6 2005 Non Starter... please help.
Results 1 to 8 of 8
  1. A6 2005 Non Starter... please help.
    Jan 2016
    Kent
    Hi all,
    Hope someone can give me some clue on where to start looking
    Used car yesterday, started no probs, got home parked, approx 3pm
    got in car at approx 4.20pm car wont start.... no hint of life...?
    Battery level indicator showed 100%
    cant hear if starter motor is trying... but it did click, though not every time.....
    Battery level today was showing 0% on the lowest bar of the level indicator....
    wont jump start, battery seems to be struggling to charge.. the only thing I have not tries is the bump start...
    Battery is just over a year old, but struggling to understand what drained it overnight....?
    Any clues... on what to try...?
    Thanks in advance
  2. Re: A6 2005 Non Starter... please help.
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Have you checked voltage of battery should be 12.5 volts at least. Checked Battery leads and earth leads to chassis and engine. Then you need to check starter leads and T.15 (small wire) to the starter. It could be any one of the suggestions. Or, of course a faulty starter.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: A6 2005 Non Starter... please help.
    Jan 2016
    Kent
    Hi thanks for your response,
    yes checked the battery.... its been on the car over 1 year... suspecting the starter....
    would any of these things just suddenly 'go' without any warning etc...
    theres been no problems starting it, no warning lights recently etc....
    M
  4. Re: A6 2005 Non Starter... please help.
    Nov 2012
    Somerset UK
    Nippy I had a brand new battery fail after a week on my profile car earlier this year...it had a 4yr warranty so just returned it for a replacement.
    That should be your first post of call, if you've checked the battery what was the voltage under load? Also what was the output from your alternator?
    Oh, it would help if you put your year/engine/transmission in your signature strip, that way you'd not need to state in your posts
  5. Re: A6 2005 Non Starter... please help.
    Jul 2007
    glasgow
    35 Post(s)
    check battery for dud cell(s) ........................ free check
    check alternator for output ............. around 14.5 volts
    check battery for volts , also then check jump start terminal for volts ............................................. should be around the same as the battery
  6. Re: A6 2005 Non Starter... please help.
    Jan 2016
    Kent
    Thanks for all your replies, it bump starts no problems
    Have removed the starter motor and it is dead
    Replace it with new starter.....tested definitely works!
    Put in car... Nada!
    Testing all circuits currently and making sure all the routes aren't broken etc......
    We shall see.....
    Audi A6 2005 2.0 TDi
  7. Re: A6 2005 Non Starter... please help.
    Nov 2008
    20 Post(s)
    I did say to check your ignition live at the starter, may have saved you a job.
    Alan.
  8. Re: A6 2005 Non Starter... please help.
    Jan 2016
    Kent
    Evening,
    Thanks for the responses.......
    It was one of the connector plugs/sockets that for some reason wasn't locked in, in the first place.... The old starter motor was dead..... It was on checking all the connections that the plug contacts was not making contact..... Stupid....simple but have a running car now coincidence it went wrong all at once
    Thanks all
  1. Please Help Non starter - suspect starter motor.
    By 94golfcl in forum Golf MK3 - 1993 - 1999
    Last Post: 18-01-2010, 10:09 AM
  2. 2005 tdi (150) non starter.
    By superbigal in forum Golf MK5 - 2004 - 2009
    Last Post: 04-01-2010, 02:01 PM
  3. Please Help Non starter! H.E.L.P !
    By trotski_101 in forum Golf MK2 - 1984 - 1992
    Last Post: 05-06-2009, 10:55 AM
  4. Non-Starter
    By alex_mcc in forum Golf MK3 - 1993 - 1999
    Last Post: 01-10-2007, 07:08 PM
  5. non starter
    By polar in forum Audi A3 - Archive Topics
    Last Post: 02-01-2007, 03:33 PM
