Thread: Audi a4 1.9tdi b6 fuel filter change
  1. Audi a4 1.9tdi b6 fuel filter change
    Apr 2016
    Durham
    Audi a4 1.9tdi b6 fuel filter change are there any instructions thanks
  2. Re: Audi a4 1.9tdi b6 fuel filter change
    Sep 2016
    GB
    Very easy job i did mine today. Yours is probably in the engine bay if not under the car around the fuel tank. Before you start just crack the fuel cap open to release any air pressure. The filter will have a clamp around it just undo this. There should be 3 or 4 hoses on the filter. One in from fuel tank one out to engine and a return from the engine. There will be plastic clips that you just push the tabs in and pull the hose off. Just pull the hose off replace them on the new filter and clamp it back in. The engine might struggle to start because the fuel has to get through the new filter. Easy
    A6 2.0TFSI Avant
  1. Question 2008 VW golf 1.9tdi bluemotion fuel filter change
    By Golf TD in forum Golf MK5 - 2004 - 2009
    Last Post: 19-01-2017, 06:37 PM
  2. Audi A4 2.5 TDI Fuel Filter Change
    By digger42 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-03-2016, 10:49 PM
  3. Audi A6 C6/4F V6 TDI Fuel Filter Change
    By Guest 2 in forum Audi
    Last Post: 03-05-2015, 08:46 PM
  4. audi a4 fuel filter and air filter change intervals??
    By sps in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-01-2014, 11:24 PM
  5. Question where is the fuel filter located on the 1.9tdi?
    By cusford in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 05-12-2009, 11:32 PM
