Thread: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
Results 1 to 9 of 9
  1. VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Does anyone know if fault codes (if any) should show using an unregistered version of VAGCOM 311-2 ?
    I get some of the measurements etc but as its not registered some options are blanked out.
  2. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Oct 2005
    Upgrade to VCDS Lite and try again
    Ross-Tech: VCDS-Lite: Download
  3. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Cheers Sam, I will do that later. Will it work with the cable I use for vagcom?
    Sent from my SM-G920F using Tapatalk
  4. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Oct 2005
    Quote Originally Posted by colty View Post
    Without knowing what cable you have, I can't say. If you look at the link in my post it should tell you which cables will and won't work though.
  5. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Ok, I will give it a go later and let you know, cheers
  6. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Hi Sam, I have vcds-lite working with the cable, should I be able to get the scope working? Thanks for the help
  7. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Oct 2005
    Trying would be the best way to find out
  8. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Hi Sam, got it working thank you, seems 1 cylinder is compensating for the other 3 so might is down
  9. Re: VAGCOM 311-2 Fault Codes, should they com eup on unregistered Version?
    Mar 2016
    Loughborough
    Mpg not might, auto correct 😀
  1. vagcom 311.2
    By mogsy in forum VCDS - Help Requests
    Last Post: 10-02-2017, 10:14 AM
  2. VAGCOM Fault Codes - what do they mean? - is she gonna blow?????
    By Dan Glibitz in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-11-2012, 11:31 PM
  3. VCDS 908.2 / 311 vagcom, won't find #46 cent. conv on 2001 A6 tdi ... help!
    By jontawn in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 24-06-2010, 11:22 PM
  4. Replies: 1
    Last Post: 23-06-2010, 10:19 PM
  5. had the fault codes checked on vagcom
    By Hurley1611 in forum VCDS - General Questions
    Last Post: 26-02-2009, 08:33 PM
