Thread: Key fob problem
  1. Key fob problem
    Mar 2013
    Reading
    31 Post(s)
    Hi all,
    I have a strange problem with one of the key fobs. It stopped working (no low battery warning or similar) but not entirely... Every now and then it will actually unlock/lock the car (2 out of 10 maybe. When it does not work, there is no light indication on the fob itself. A quick scan shows this:
    05 Kessy
    System description: BCM2 2.0
    Software number: 4H0907064CN
    Software version: 0433
    Hardware number: 4H0907064CN
    Hardware version: H33
    Long coding: 01B93046000000000000
    Subsystems:
    System description: J764 ELV MLB
    Software number: 4H0905852C
    Software version: 0046
    Hardware version: H40
    Serial number: 2313000071043014
    Trouble codes:
    00955 - Key 1 Lower limit not reached
    Intermittent
    BTW I do not have advanced key - it is the "normal" one.
    Any ideas? (I will change the battery just in case but that was done relatively recently so not much hope)
  2. Re: Key fob problem
    Mar 2014
    Edinburgh
    235 Post(s)
    I had something similar and changed the battery and it all worked.
  3. Re: Key fob problem
    Feb 2017
    Lincoln, UK
    I replaced my battery recently because of an almost identical fault. Since then, everything has been fine. I hope you get yours fixed soon.
    FL A6 S Line Ultra Avant in Glacier White - 19" 10-spoke wheels - Tech Pack - Ambient Lighting - Memory Seats - Electric Boot - Bose
  4. Re: Key fob problem
    Mar 2013
    Reading
    31 Post(s)
    Thanks chaps, replaced the battery and so far so good! Interesting as the last time around I had a nice warning on the dash that it was low... Ah well... It is nice when simple things solve the problem!
    Sent from my mobile...
  5. Re: Key fob problem
    Mar 2014
    Edinburgh
    235 Post(s)
    I noticed in mine at home it was fine but at work it was a struggle even to get the car to unlock with a new battery. There's a lot of radio interference and at work there's a mobile mast so most folk I know needs to be next to their car before they can unlock. So with a weak battery the interference is going to play havoc with these keyless type remotes.
  1. Please Help 2001 1.9TDI power problem, freezing trip computer and starting problem
    By chapster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 23-10-2014, 12:44 PM
  2. Sat Nav problem? Or user problem? Can't select postcode entry.
    By rafletcher in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-09-2012, 10:41 AM
  3. Replies: 19
    Last Post: 24-12-2011, 09:45 PM
  4. Exhaust emissions/temperature gauge problem/starting problem
    By joncope in forum Polo - Derby - Lupo - Fox
    Last Post: 06-07-2009, 04:31 PM
  5. Stuck door problem, central locking problem & no alarm
    By andyaudia4 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-11-2008, 05:57 PM
