Thread: RNS-E FM radio signal poor
  1. RNS-E FM radio signal poor
    Jan 2014
    Birdgwater somerset United Kingdom
    Heya guys,
    I have bought a 2005 audi c5 allroad with factory fitted RNS-E a few days ago and I have noticed that the FM radio stations don't seems to be picked up very well. They are all greyed out apart from BBC Radio 1 and sometimes I get the odd one that will highlight and I can select like BBC Radio 3 or Heart. On the manual tuning if I scan i find nothing and if i tune it manually to the frequency of the stations I know then they pick up ok. Maybe not perfect signal but ok. Close enough as to I would think it would find it on an auto scan.
    It also has a load of stations lower down the list that seem to be a random muddle of letters that aren't greyed out but you can't select them??
    Before O started driving the car I did buy a new Maps disc off of ebay with the 7 digit post code entry so I was wondering if this non official disc has messed with it? I think it worked ok before this? Can't really remember. I think it did because I went through saving my favorite stations to the memory.
    Please help
    Instagram: @lukeybabes
  2. Re: RNS-E FM radio signal poor
    Jan 2014
    Update. I thought id be able to downgrade the firmware to the origonal disc to test but I need a registered version of vag com to do that. Might just register it as I was to adapt a few other things too.
    I also went onto the engineering mode of the RNS-E and when in that I can tune the radio perfectly fine. So that would suggest all the hardware is working ok. Right?
  3. Re: RNS-E FM radio signal poor
    Jan 2014
    I managed to install the old firmware onto the rns-e using vag com using this method. Need an activated version though.
    Quote Originally Posted by Tabletski View Post
    To downgrade the software, have an older DVD ready and follow the steps listed below:
    - remove the DVD
    - connect with VAG-COM to #37
    - set channel 97 to 1 and save the value
    - exit VAG-COM
    - insert the old DVD that contains the software you want to downgrade to
    - wait until the RNS-E finishes the update (starts a few seconds after inserting the DVD, will reboot twice and then power off)
    - connect with VAG-COM to #37 channel 97 and save the value of 0
    Now the radio works as it should. But obviously I still want the features from the new disc. But that's a new problem.
    At least I know its the software on the disc though.
    Case closed
  1. Replies: 7
    Last Post: 30-06-2011, 11:12 PM
  2. A4 poor radio signal
    By Hammerman in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-05-2011, 12:26 PM
  3. Radio signal - very poor !!!!!!
    By BIG_GAZ_A6_V6 in forum In Car Entertainment
    Last Post: 27-02-2011, 12:27 PM
  4. Sony Radio MW Poor Signal
    By Kiethlard in forum In Car Entertainment
    Last Post: 28-01-2010, 07:36 AM
  5. Please Help Very poor radio signal reception
    By amonshol in forum In Car Entertainment
    Last Post: 09-03-2009, 10:28 PM
