Thread: CAN Bus wiring issues?
  1. CAN Bus wiring issues?
    Cornwall
    I have a number of what I would consider to be CAN bus connection/communication issues and wanted to inspect the loom in the areas of junctions/joins.
    I have a wiring diagram, but am not sure of the routes of the wiring and where the splices might be. I understand that there are some on the drivers side sill area under the carpet and this is a common problem area?
    I physically checked accessible connections to the ABS, EEC, central convenience module and the instrument cluster, I would be grateful for any pointers to common failures in these areas. Recent history of the car is one year stored in damp conditions, mildew evident in car, now mostly dried and cleaned, but I suspect moisture ingress to be the main culprit. Plenum chamber had an estimated 1L of water, so probably more at one point and likely to be cause of damp carpets.
    Auto-scan attached to show the current issues.
    Code:
    Friday,03,February,2017,19:17:48:38737VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.1.2.1 (x64)
    Data version: 20170131 DS267.1
    www.Ross-Tech.com
    VIN: WVGZZZ7LZ3D008777   License Plate: SY03HFT
    Mileage: 115390km-71700mi   Repair Order: Air quality sensor Cx
    Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
    Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
              37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
    VIN: WVGZZZ7LZ3D008777   Mileage: 115390km-71700miles
    Address 01: Engine        Labels: 077-907-560-AXQ.lbl
       Part No SW: 4D0 907 560 BQ    HW: 8E0 907 560
       Component: 4.2L V8/5V      G   0050
       Coding: 0011875
       Shop #: WSC 31414 000 00000
       VCID: 76E9DA7802506CF1C8-5140
    4 Faults Found:
    17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28)
                P1340 - 001 - Incor. Correlation - MIL ON
    17887 - Brake Boost Vacuum System
                P1479 - 008 - Mechanical Failure
    16815 - Warm Up Catalyst; Bank 2
                P0431 - 001 - Efficiency Below Threshold
    16805 - Warm Up Catalyst; Bank 1
                P0421 - 001 - Efficiency Below Threshold
    Readiness: 0000 0101
    Address 02: Auto Trans        Labels: 09D-927-750.lbl
       Part No: 09D 927 750 J
       Component: AL 600 6Q           0346
       Coding: 0004136
       VCID: 356B1D745FD627E901-5140
    No fault code found.
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
       Part No: 7L0 907 379 B
       Component: ESP ALLRAD MK25     0106
       Coding: 0014337
       Shop #: WSC 71233 144 00001
       VCID: 3875144048C4DA811A-5124
    Address 05: Acc/Start Auth.        Labels: 3D0-909-13x-05.lbl
       Part No SW: 3D0 909 131 T    HW: 5WK 470 21
       Component:    Kessy            6120
       Coding: 0000232
       VCID: 32612668AEB830D124-5140
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: ELV                 XXXX
    7 Faults Found:
    01336 - Company Data Bus for Comfort System
                014 - Defective - Intermittent
    00457 - Control Module for Network (J519)
    00956 - Key 2
                002 - Lower Limit Exceeded
    01330 - Central Control Module for Central Convenience (J393)
    01314 - Engine Control Module
    01316 - ABS Control Module
    01299 - Diagnostic Interface for Data Bus (J533)
                005 - No or Incorrect Basic Setting / Adaptation - Intermittent
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 D
       Component: CLIMAtronic R/L     0302
       Coding: 0001020
       VCID: 31632964ABBE0BC95D-5140
    1 Fault Found:
    02100 - Footwell Flap Motor (V261)
                000 -  -  - Intermittent
    Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
       Part No: 7L6 937 049 K
       Component:                     2701
       Coding: 0100412
       VCID: 448D70B0040C8E6186-5124
    1 Fault Found:
    00907 - Intervention load Management
                000 -  -
    Address 15: Airbags        Labels: 3D0-909-601.lbl
       Part No: 3D0 909 601 B
       Component:  4 Airbag 8.4E+ H07 0641
       Coding: 0008244
       Shop #: WSC 00000 000 00000
       VCID: 2241D628FE58A051D4-5124
    Address 16: Steering wheel        Labels: 7L6-953-549.lbl
       Part No: 7L6 953 549 B
       Component: Lenksäulenmodul     3201
       Coding: 0000011
       VCID: 3E7902586AE0E4B1D0-5140
    Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
       Part No: 7L6 920 970 P
       Component: KOMBIINSTRUMENT RB8 2035
       Coding: 0007411
       Shop #: WSC 00792 210 91867
    1 Fault Found:
    00470 - Company Comfort Databus in Single Wire
                011 - Open Circuit
    Address 19: CAN Gateway        Labels: 6N0-909-901-19.lbl
       Part No: 6N0 909 901
       Component: Gateway K<>CAN      0101
       Coding: 0000006
       VCID: 70E5EC60603442C112-5140
    1 Fault Found:
                011 - Open Circuit
    Address 22: AWD        Labels: None
       Part No: 0AD 927 755 BE
       Component: TRANSFERCASE        0122
       VCID: 7F073F5C2D6A2DB99B-5140
    1 Fault Found:
    Address 46: Central Conv.        Labels: 7L0-959-933.lbl
       Part No: 7L0 959 933 C
       Component: JM HSG              3203
       Coding: 0000065
       Shop #: WSC 00792 210 59061
       VCID: 3C7D08507CFCF6A1FE-FFFE
       Subsystem 1 - Part No: 7L0 959 701 D
       Component: Tuersteuergeraet FS 0104
       Subsystem 2 - Part No: 7L0 959 702 D
       Component: Tuersteuergeraet BF 0104
       Subsystem 3 - Part No: 7L0 959 703
       Component: Tuersteuergeraet HL 0104
       Subsystem 4 - Part No: 7L0 959 704
       Component: Tuersteuergeraet HR 0104
       Subsystem 5 - Part No: 7L0 907 719
       Component:    Neigungssensor   0018
       Subsystem 6 - Part No: 7L6 951 171
       Component: A  Innenraumsensor  0019
    Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
       Part No: 7L6 035 195
       Component: Radio DE2           0003
       Coding: 0001407
       VCID: 70E5EC60603442C112-5124
       Subsystem 1 - Part No: 7L6 035 195
    No Faults Found
      or DTCs not supported by controller
      or a communication error occurred
    Address 68: Wiper Electr.        Labels: None
       Part No: 7L0 955 119 G
       Component: Front Wiper         2416
       Coding: 0000004
       Shop #: WSC 31414 000 376832
       VCID: 3875144048C4DA811A-5140
    End---------------------(Elapsed Time: 10:52, udsna)-----------------------
  2. Re: CAN Bus wiring issues?
    Sep 2008
    mostly in the garage
    The front passsenger footwell is known problem area where water ingress can corrode wiring....worth lifting the carpet as it's not always obvious that it's wet underneath.
    I assume you have cleaned the plenum drains behind the wheel arch liners?
  3. Re: CAN Bus wiring issues?
    Cornwall
    Yes, plenum areas drained, as that's where the water was found. I'll have a look under the carpets and provide feedback.
    So are you saying both footwells have problems on these cars, or is it dependent on which side the steering and controls are?
  4. Re: CAN Bus wiring issues?
    Sep 2008
    Yes both sides, behind kick plates and below carpet. Passenger side seems more common, perhaps simply because of road camber when parked. The harnesses will need to be opened up going forward to reveal splices. Not saying this is your issue just common areas for electrical
    gremlins.
  1. Audi A4 B7- Upgrading head unit, can-bus issues.
    By matt_uk in forum In Car Entertainment
    Last Post: 30-05-2014, 06:38 PM
  2. Passat BMT Estate B7 CAN bus wiring
    By Trailertrash in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 18-08-2013, 03:46 PM
  3. GOLF V BUS-CAN or BUS R-LADDER ???
    By DSGFAN in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2009, 12:26 AM
  4. Question 2003 A4 V6 TDi starting issues and is my car can bus ?
    By ShaunD in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-02-2009, 04:27 PM
  5. Please Help Golf VS Bus...Bus wins
    By LSDJ in forum Golf MK4 - 1999 - 2004
    Last Post: 02-06-2008, 06:32 PM
