Thread: Navigation and Spoiler Issue after Flat Battery
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Navigation and Spoiler Issue after Flat Battery
    #11
    Mar 2008
    11 Post(s)
    Unsure about the model you have but I can check mine over the weekend - However in my C6 A6, I had plugged the car into VCDS/Laptop and there was a battery module that you could go into to check the voltage and what not including battery state which gave you a percentage of the battery charge/health from memory
    This might help: Can I use VCDS to check the alternator / battery charging OK ?
    Audi A7 Black Edition 3.0 TDI (272) 2015 (FL)
  2. Re: Navigation and Spoiler Issue after Flat Battery
    #12
    Mar 2008
    11 Post(s)
    Quote Originally Posted by AK88 View Post
    i believe mine is set on 12.1, no less and the camera is now off less than 24hrs into parking mode.
    I think I will look into the trickle charger, don't know whats happened for the battery/charge to deplete as I had no issues around 6 weeks ago.
    is there an easy way I can check the voltage of the battery? and what should a healthy battery voltage be?
    Cheers,
    Today was less car day apart from putting in the last of the LED lights as I broke one trying to remove it however I did jump into the car to do a quick scan and search for you via VCDS. What I found is the normal measuring blocks icon is blocked out but the advanced one was not and I found my answer there - I think.
    So plug the car in, and open up Module 19 - CAN Gateway
    Then click on Adv. Meas. Values (under Basic Functions)
    This will open up a VCDS Advanced Measuring Values screen and also a "Click for Selection " screen which is essentially a set of bits you can check to monitor.
    In there, check the Battery ones that you want to measure. In my case I did the following which got me the following results:
    Battery variant - Manufacturer: JCI
    Battery variant - Size: 92 Ah
    Battery Voltage : 12.206v
    Battery Current filtered: -16.200A
    Battery Current: -16.289A
    Temperature of battery sensor: 15
    Battery temperature: 14
    Battery charge condition: 81%
    Battery condition for display: 80%
    Battery internal resistance: 3.2 mOhm
    Usable battery charge: 45 Ah
    From memory when I used to monitor the A6 C6 battery, it was the battery condition that was useful. I can't remember the in's and out's of it however there are plenty of threads explaining it but from memory, once it got to 60-70% it was probably worth planning on changing it?
    Mine is 81% however I was sitting in the car for a good 30 mins with heated seats on, radio on and fans on minimal and so it might change once the trickle charger does it's thing.
    Hope this helps! What is interesting is it's a 92 Ah battery, pretty sure my the A6 C6 was 110. Never checked the A6 C7 so can't compare.
  3. Re: Navigation and Spoiler Issue after Flat Battery
    #13
    Aug 2015
    West Mids
    7 Post(s)
    Well I recived the car back today from the dealer after 4weeks in their hands, the work carried out:
    Spoiler:
    Spoiler control unit
    New spoiler mounting and Bracket
    Nav:
    Replaced entire roof aerial
    All seems to be working fine now, the costs on the invoice mount upto £1280 excluding the VAT and this would have been more on labour had it have been out of warranty !! unbelievable cost considering these are relatively small issues.
    As part of the investigation of the rear spoiler in the notes the detail "lubricated spoiler" I assume this would be to 2 hinges - so does anyone out there lubricate the brackets? I have the spoiler on the auto setting so only really pops up on the motorway
    I know I will be following up on the extended warranty now.
    Audi A7 (2012), Black Edition 245 PS Tiptronic, Phantom Black
  1. Please Help Flat Battery?!
    By Craigk2809 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-05-2012, 12:48 PM
  2. How To flat battery
    By scotty b in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-01-2012, 09:37 AM
  3. A6 flat battery
    By chris ha6 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 27-06-2011, 09:59 PM
  4. Question Flat battery
    By pash06 in forum Golf MK4 - 1999 - 2004
    Last Post: 16-09-2009, 01:30 PM
  5. Please Help Battery going flat
    By Percy2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-02-2009, 02:46 PM
