Hello everybody!
I have a problem with Seat Altea 1.9TDI 105hp 2005. Recently the Bordnetz-SG H34 0803 module was replaced because the previous one was broken (one of the chips inside was burned which caused different problems with the exterior light on the car). After replacing the module and coding everything there 2 faults which I cannot delete causing the yellow bulb sign on the dashboard being constantly on. Another problem I have is when the car is started and in idle the exclamation mark is on ( the same one for the pulled up handbrake ). The most annoying part comes when I start driving the car the sign start blinking and horrible beeping sound comes. At first I was thinking might be blocked caliper (checked everything no problem) then I was thinking might be leaking (nope), of course level of the break fluid (nope) so I have no idea. Recently I have been told that this could be because of the error I have for the tail lights fault might be causing this. I have checked everywhere and I cannot find cure for that. I really Hope someone can help auto scan is posted below!
btw Also the cruise control refuse to work without a reason...
Code:
Thursday,02,February,2017,13:08:26:25996
VCDS Version: 17.1.2.0 (x64)
Data version: 20170127 DS267.1
www.Ross-Tech.com
VIN: VSSZZZ5PZ5R083230   License Plate:
Chassis Type: 5P (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 7D
VIN: VSSZZZ5PZ5R083230   Mileage: 310770km-193103miles
01-Engine -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
7D-Aux. Heat -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 HC    HW: 028 101 228 9
   Component: R4 1,9L EDC 0000SG  7000
   Revision: 12345678    Serial number: SEZ7Z0E2919894
   Coding: 0050071
   Shop #: WSC 06402 785 00200
   VCID: 6BD5BB594AE07C1926-803E
1 Fault Found:
18049 - Please check DTC Memory of A/C Controller
            P1641 - 000 -
             Freeze Frame:
                    RPM: 819 /min
                    Torque: 24.4 Nm
                    Speed: 0.0 km/h
                    Load: 0.0 %
                    Voltage: 14.06 V
                    Bin. Bits: 11000000
                    Temperature: 61.2C
                    (no units): 0.0
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021234
   VCID: 3A7B4E1D753A1591ED-806E
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No: 5P0 820 047 J
   Component: Climatic PQ35   007 0201
   Shop #: WSC 00000 000 00000
   VCID: 34676025575EE3E137-8060
1 Fault Found:
00819 - High Pressure Sensor (G65)
            009 - Open or Short to Ground
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001436490
   Coding: A8888F0600041000001400001400000000087F075C
   Shop #: WSC 00046 412 185139
   Subsystem 1 - Part No: 5P0 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer SE359  012  0402
   Coding: 00056272
   Shop #: WSC 00046
2 Faults Found:
00984 - Left Tail Light (M4)
            012 - Electrical Fault in Circuit
00985 - Right Tail Light (M2)
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 K    HW: 1K0 909 605 K
   Component: S3 AIRBAG VW8   024 0700
   Revision: 07024000    Serial number: 00378D05YSLX
   Coding: 0021299
   Subsystem 1 - Serial number: 6332MSME494D6807
   Subsystem 2 - Serial number: 6342MSME69217708
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AK    HW: 1K0 953 549 AK
   Component: J0527           032 0070
   Coding: 0000042
   Shop #: WSC 00257 204 05160
   VCID: 7BF58B193A80EC99B6-802E
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 5P0 920 822 G
   Component: KOMBIINSTRUMENT VO3 1058
   Coding: 0002101
   Shop #: WSC 11111 111 11111
   VCID: 336563395250E4D92E-8066
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 27001052010803
   Coding: 3D0F0B40078202
   VCID: 29598151809CAE0994-807C
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                1058
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX1.lbl
   Part No: 1T0 959 701 A
   Component: Tuersteuergeraet 09 0139
   Coding: 0000048
   VCID: 35615D215C24FAE900-8060
1 Fault Found:
00928 - Locking Module for Central Locking; Front Driver Side (F220)
            008 - Implausible Signal - Intermittent
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K1 909 144 H
   Component: EPS_ZFLS Kl.10      1502
   VCID: 306F6C35A346DFC153-8064
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 00C0009C2D0005050001000000D4
   VCID: 79F9911130BCDE89A4-802C
   Subsystem 1 - Component:   Sounder n.mounted
   Subsystem 2 - Component:       NGS n.mounted
   Subsystem 3 - Component:      IRUE n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX1.lbl
   Part No: 1T0 959 702 A
   Coding: 0000048
   VCID: 36635A2D4122F1F109-8062
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No: 5P1 035 152
   Component: Radio BNO           0031
   Coding: 0020400
   VCID: 66C3CA6D5102417179-8032
1 Fault Found:
00856 - Radio Antenna
            011 - Open Circuit
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
   VCID: 2D517541B474B22978-8078
1 Fault Found:
00361 - Heater Element for Auxiliary Heater (Z35)
            014 - Defective
End-------------------------(Elapsed Time: 01:28)--------------------------
