Thread: Leak with a twist - it's not the battery drain or pollen filter housing.
Results 1 to 10 of 17
  1. Leak with a twist - it's not the battery drain or pollen filter housing.
    Jan 2017
    Berkshire
    Hi All,
    I have managed to spend approx 1.5 weeks drying my car (3 inches of water in the rear footwells!) by having all the carpets up and exposing the insulation.
    I removed the drain plug under the battery and took the pollen filter housing off, cleaned it up, re-sealed it, replaced etc. I still have water getting into the footwells!
    Both sides were wet yesterday after rainfall - any idea where else this was coming from? It seemed to be only in the foot wells right underneath the dash, so not coming in through the doors. Anywhere else it could be? I'm tempted to just attack everything under the bonnet with silicone!
    Thanks.
  2. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    May 2012
    Everywhere
    308 Post(s)
    Bonnet cable grommet and ECU seal or windscreen if it isn't the door seals .
  3. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    Jan 2017
    Berkshire
    Thanks - I did think of attacking the bonnet cable grommet with silicone so will do that. My windscreen plastic bit that slots into the windscreen has about an inch on the driver's side where it isn't connected, could it be getting in there somehow? Was planning on siliconing that down.
  4. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    May 2012
    Everywhere
    308 Post(s)
    ECU housing seal ?
  5. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    Jan 2017
    Berkshire
    Quote Originally Posted by Gazwould View Post
    ECU housing seal ?
    Another good suggestion - will attack with the silicone too! Thanks.
  6. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    1841 Post(s)
    You say rear footwells then imply only front. If the drain under the battery and under thr servo are clear then water can't get into the front left floor from below the filter housing but it can drip down from the screen trim directly onto the filter, but that won't get into the right. Sunroof model? I would be taking all the door supports out, wire wheeling the lower area to remove the rubber seal and re-seal using Butyl cord, please don't use Gorilla snot...
  7. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    Jan 2017
    Berkshire
    rear footwells was pre- me doing the work, now it's only front footwells directly under the dash (both carpets are still up, no seats in the car currently) The foam bit that backs onto the bulkhead is soaked so assume the water is getting inside via that.
    Gorilla snot? The hair cream? 99% sure it's coming from below the dash at the front, as all the carpet is still up and literally only wet under there, no water on the side near the doors etc.
  8. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    May 2012
    Everywhere
    308 Post(s)
    A new ECU housing seal is £3 .
    1 1 0
  9. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    1841 Post(s)
    Gorilla snot is what I call silicone sealant when it's smothered all over the place, horrid stuff.
  10. Re: Leak with a twist - it's not the battery drain or pollen filter housing.
    Jan 2017
    Berkshire
    On back order with VW, and no idea when they'll have them in. Guess I'll make my own instead.
  1. Question Pollen Filter Housing Removal
    By hudsonm in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-06-2010, 02:41 PM
  2. Please Help Leak through pollen filter!!
    By olliew007 in forum Audi A3 - Archive Topics
    Last Post: 17-03-2009, 08:21 PM
  3. How to remove pollen filter housing?
    By wilharper2000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 20-01-2009, 09:05 PM
  4. Pollen filter leak fault
    By dazwalker in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-01-2008, 10:51 PM
  5. Pollen Filter housing removal
    By mgarner in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-07-2007, 09:30 AM
