Thread: Audio system fault on bang and olufsen option
  1. Audio system fault on bang and olufsen option
    Jan 2017
    preston united kingdom
    desperate for a happy ending here but I fear the worst.my a4 allroad s audio is faulty.The DAB radio has gone off altogether .the sound plays ok through an SD card but here is the problem.
    The sound plays for @28 seconds then goes off,it comes back on again after 2 seconds in the same beat in time as if is been playing ok.The volume level has reset to default level.
    an independent audi garage has checked the system and said there was light flowing into the amp but not passing through.He suspected the amp.So I contacted the amp repair people in Edinburgh and they said the symptoms I am reporting are not likely the amp.
    the car has been diagnosed by Preston Audi . a quick check and £60 later they advised that the audio head unit isn't working and that I need a new one .......£1250 please.
    Is there any advice you can offer about a repair ??
  2. Re: Audio system fault on bang and olufsen option
    Ardfern
    8 Post(s)
    You could buy a s/h one and see if it works although you would need the CP taken off by your friendly Audi dealer. Might be a lot cheaper in the long run.
    A4 B8 143 Tdi S Line Saloon 2008 (Gone)
    Lotus Elan SE 1991
    A4 B8 170 Tdi Quattro Technik Avant 2011
    A4 B8.5 143 Tdi S Line Black Edition Saloon 2013(gone)
    A4 B8.5 Allroad Sport Nav 2.0 tdi quattro 2015
  3. Re: Audio system fault on bang and olufsen option
    Jan 2017
    I thought a second hand unit was a no no due to codings etc...... it it possible to connect a unit from another car to mine ??
  4. Re: Audio system fault on bang and olufsen option
    Ardfern
    8 Post(s)
    As I wrote, you would have to have the CP (Component Protection) removed by Audi, but subject to that, there is no difficulty. I did this when I fitted a head unit with DAB in place of the factory-fitted one without.
    The important thing is to ensure that you don't buy a unit which Audi refuse to assist you to fit-i.e. one they suspect has been stolen.
    Lotus Elan SE 1991
  1. Bang & Olufsen Sound System
    By chiefinspector in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 07-08-2015, 12:49 PM
  2. Bang & Olufsen volume dropping down
    By G-Force in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 19-04-2014, 07:42 PM
  3. Question Bang and Olufsen, which sd card?
    By gord115 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-11-2012, 06:19 PM
  4. bang and olufsen
    By steeevo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-02-2009, 10:07 AM
  5. Free Bang & Olufsen option with new A4
    By AUDI-NUT in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-04-2008, 11:43 PM
