Thread: sticking vanes on my turbo?
  1. sticking vanes on my turbo?
    Oct 2006
    Hi all, I drive an audi 1.9tdi avant.
    I have noticed that when my turbo kicks in I leave behind me a cloud of black smoke. When the turbo doesn't kick in there is no smoke. Does this mean that the vanes in the turbo are sticking?
    Cheers.
  2. Re: sticking vanes on my turbo?
    Apr 2007
    Lancashire
    Do you have any associated power loss, as sticking vanes will put you into reduced power 'limp mode'.
    A little black smoke is normal when you put your foot down, especially if the car has been remapped or is running a tuning box.
    TDI's also tend to burn a little engine oil that gets blown along the boost hoses.
    Excessive black smoke could indicate a problem (normally a high pressure boost leak).
  3. Re: sticking vanes on my turbo?
    Oct 2006
    Thanks ini,
    There is no power when the turbo doesn't kick in, when it does kick in there's more power but not a kick in the back feeling. The smoke could be grey it's hard to tell from the rear view mirror.
  4. Re: sticking vanes on my turbo?
    london/ UK
    Quote Originally Posted by barney2 View Post
    Thanks ini,
    Change the air filter and see if its clearing. If not and the car its running on original nozzles, you might wanna replace them as well ! They wear out in high milleage motors and the spray pattern will be less than ideal, then the fuel won't ignite- hence the black smoke !
  1. Brakes Sticking on
    By Chriscross in forum Passat - Archive Topics
    Last Post: 07-01-2008, 10:28 AM
  2. Mk 3 Accelerator Sticking
    By jamescurrer in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 08-08-2007, 01:15 PM
  3. Sticking window
    By chrisball666 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-07-2007, 08:55 PM
  4. Sticking
    By Jum in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 24-03-2007, 01:09 AM
  5. variable nozzle vanes on tdi turbocahrger
    By glynnd in forum Passat - Archive Topics
    Last Post: 31-05-2006, 01:31 PM
