Hy recently i have a problem to my car :dpf on flashing glow plug and engine management light on --- and the car is in limp mode
If i activate a service regeneration(with vcds interface) the engine is working normaly not limp mode (warning light are still on) .
How can i reset tis errors and after that to try again a service regeneration .
It is posible that this isues be caused by egr ???
i use a vcds interface to scan for error codes and here is a part of log file
FOR Engine
ddress 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 LP HW: 03L 906 023 JH
Component: 1,6l R4 CR td H43 8810
Revision: --H43--- Serial number:
Coding: 00114016032400080000
Shop #: WSC 30924 001 1048576
ASAM Dataset: EV_ECM16TDI02103L906023LP 003005
ROD: EV_ECM16TDI02103L906023LP.rod
VCID: 7F0A9BD3E6EEDBC624-802A
1 Fault Found:
16848 - Diesel Particulate Filter
P2458 00 [175] - Regeneration Duration
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 175084 km
Date: 2017.01.26
Time: 09:50:19
Readiness: 0000 0000
And here some mesurments of EGR
016 Actuator for high pressure EGR; status-LF_STATE_EGRV_DISP[0] 6
073 EGR Vacuum Regulator Solenoid Valve; activation-ANG_SP_EGRV[0] 0.000 %
074 EGR valve; offset closed-V_EGRV_BOL[0] 0.928 V
075 EGR valve; offset open-V_EGRV_TOL[0] 3.999 V
129 Exhaust flap; actual value-ANG_EGRV[0] 0.000 %
130 Exhaust gas recirculation (EGR) cooler pump; specified value-PWM_EGRCP[0] 95.001 %
156 High press EGR actuator; actual unconditioned volt val-V_EGRV[0] 0.928 V
160 High pressure EGR actuator; activation-PWM_HBR_EGRV[0] -15.436 %
384 EGR_control_deviation_lower_limit-EGR_DIF_MIN_DIAG 0.000 %
385 EGR_control_deviation_upper_limit-EGR_DIF_MAX_DIAG 0.000 %
386 EGR_deviation-EGR_DIF 0.000 %
