Thread: Touareg Brakes Coming on when driving
Page 1 of 3 123 LastLast
Results 1 to 10 of 25
  1. Touareg Brakes Coming on when driving
    Jan 2017
    Crewe
    Hi, I am a new Touareg owner and new to forum, I searched on brakes and see nothing similar.
    Car - 2012 VW Touareg 3.0 TDI SE Auto, 45,000 miles
    My problem is that sometimes, getting more frequent, the brakes are lightly being applied whilst driving without any contact with the brake pedal! It get's worse if you don't stop. Stopping and restarting the car along with pressing the brake pedal seems to fix the issue until it comes on next time.
    Any ideas welcome please!
    Many thanks,
    A
  2. Re: Touareg Brakes Coming on when driving
    Cornwall
    What indication are you getting that brake pressure is applied?
  3. Re: Touareg Brakes Coming on when driving
    Jan 2017
    Crewe
    Quote Originally Posted by Overdose View Post
    Hi Overdose, the car slows as if brakes or a handbrake is being lightly applied. You have to put much more revs on to keep moving. Any ideas welcome! Thanks for replying.
  4. Re: Touareg Brakes Coming on when driving
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    Your toureg has brake assist for hill descents, it sounds as if there is a fault with that system. I'm not familiar with it (pal has a q7, but i keep clear!)but suspect there are fancy inclinometers etc that look at overun and hill angles, best bet would be a full vcds scan to see what comes up.
    1 1 0
  5. Re: Touareg Brakes Coming on when driving
    1837 Post(s)
    Is this only when the wipers are on? A full code read would be the best start.
  6. Re: Touareg Brakes Coming on when driving
    Jan 2017
    Crewe
    Hi Crasher, I do believe wipers are always on when it happens, why do you ask that? Is there a known issue there please? Thanks
  7. Re: Touareg Brakes Coming on when driving
    Pembrokeshire
    22 Post(s)
    applying brakes every now and then to keep them dry maybe... so they work fully in an emergency.
    3 2 0
  8. Re: Touareg Brakes Coming on when driving
    1837 Post(s)
    The CAN BUS tells the ABS that the wipers are on so the ABS "assumes" it is raining and so periodically applies the brakes to wipe the discs clean, if the wrong pads are used this can be to sharp, I think it is adjustable, certainly you can turn it off.
    3 3 0
  9. Re: Touareg Brakes Coming on when driving
    Nov 2010
    104 Post(s)
    You learn something new every day! Thanks.
    Why does life have to get so complicated?
    0 2 0
  10. Re: Touareg Brakes Coming on when driving
    Pembrokeshire
    22 Post(s)
    because some bright spark invented the can bus system and it all expanded from there. far far too complicated.
    0 2 0
  1. audi a6 2002 hazard lights coming on whilst driving
    By mancha in forum New Member Introductions
    Last Post: 04-04-2015, 04:27 PM
  2. Important Grinding noise coming from the rear brakes.
    By Jonny88 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-11-2011, 08:44 PM
  3. radio switching off dash lights coming on whilst driving
    By danrange4 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-07-2010, 04:59 PM
  4. Please Help Interior lights occasionally coming on while driving
    By codlord in forum Passat - B5 Forum - 1997 -2005
    Last Post: 26-10-2009, 04:07 PM
  5. A6 breaks coming on while driving
    By perryhawk in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 03-09-2009, 04:06 PM
