Thread: ODBEleven 5F Adaption Map Request
Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
  1. Re: ODBEleven 5F Adaption Map Request
    Apr 2016
    Stansted
    169 Post(s)
    What issues are you having Papereyes? Was it you that had the issue when going round a bend and the brakes slammed on?
    I've actually dialled mine up to early or sensitive (whatever the option is!). It doesn't brake any more than before but does ping up the exclamation mark just in case I'm not paying enough attention!
  2. Re: ODBEleven 5F Adaption Map Request
    Mar 2016
    KEnt
    22 Post(s)
    Mines on medium, it's more a case of just reversing slowly nothing nearby and then all of a sudden brakes jam on and then feels like u hit a train. And it's the pre sense kicking in
  3. Re: ODBEleven 5F Adaption Map Request
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by noxqzs View Post
    ;SW:4M0-035-025 HW:4M0-035-025 --- Information Electr.
    ;Component:MU-H-LNS-US 050 0377, Coding:013706020000000053220002041A00102F001BE5017 00104FE
    ;EV_MUHig6C3Gen2HBAS,001115,EV_MUHig6C3Gen2HBAS_AU 37.rod
    ;Friday,27,January,2017,14:06:32:43543
    ;VCDS Version: Release 17.1.2 (x64) Data version: 20170107 DS267.0
    ;VCID: 608C68327BE9B44183-8034
    IDE00001-Production mode,00 00 00
    IDE00346-Summertime-automatic,automatic
    IDE00759-Base volume of speech output,50 %
    IDE00768-Country identification: country of sale,US
    IDE00769-Number 1 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE00770-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
    IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
    IDE00845-Wheel circ.,0 mm
    IDE01996-ENG99724-Installation list: specified installations-ECU coded,Yes
    IDE01996-ENG99724-Installation list: specified installations-ECU coded,No
    IDE01996-ENG06573-Installation list: specified installations-ECU coded 2,No
    IDE02121-CD eject button,Enabled
    IDE02122-Developer mode,not activated
    IDE02330-Number 2 for Info call,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02331-Number 2 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02332-Deactivate production mode,0
    IDE02476-MAS03001-Electrical test of loudspeakers-Mode,automatic
    IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
    IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22
    IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
    IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22
    IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
    IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22
    IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
    IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22
    IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
    IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22
    IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
    IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22
    IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
    IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22
    IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
    IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22
    IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
    IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22
    IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
    IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22
    IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
    IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22
    IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
    IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22
    IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
    IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22
    IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
    IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22
    IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
    IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22
    IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
    IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22
    IDE02502-Confirmation of installation change,10 BA
    IDE02506-MAS03229-Copy multimedia data-Data medium,On
    IDE02506-MAS03230-Copy multimedia data-Optical drive,On
    IDE02607-Wheel pulse,0
    IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo,0
    IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP,15
    IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo,0
    IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP,15
    IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo,0
    IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP,11
    IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo,0
    IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP,8
    IDE03471-ENG117847-Vehicle configuration-advanced_range_display,OFF
    IDE03471-ENG130249-Vehicle configuration-Apple_DIO,On
    IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call,On
    IDE03471-ENG130248-Vehicle configuration-Google_GAL,On
    IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On
    IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On
    IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts,On
    IDE03471-ENG117849-Vehicle configuration-gracenote_online_other,On
    IDE03471-ENG125049-Vehicle configuration-Joker_button_1,Not Present
    IDE03471-ENG125050-Vehicle configuration-Joker_button_2,Not Present
    IDE03471-ENG127492-Vehicle configuration-LGI,OFF
    IDE03471-ENG130246-Vehicle configuration-LTE_modul,activated
    IDE03471-ENG07590-Vehicle configuration-Mirror_link,function_off_hmi_off
    IDE03471-ENG117843-Vehicle configuration-my_audi,On
    IDE03471-ENG117845-Vehicle configuration-online_dictation,OFF
    IDE03471-ENG127495-Vehicle configuration-online_media,On
    IDE03471-ENG117840-Vehicle configuration-online_navigation,On
    IDE03471-ENG117837-Vehicle configuration-online_POI,On
    IDE03471-ENG117838-Vehicle configuration-online_POI_voice,On
    IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,On
    IDE03471-ENG117841-Vehicle configuration-online_street_view,On
    IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit,OFF
    IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act.
    IDE03471-ENG117844-Vehicle configuration-picture_navi,OFF
    IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi,OFF
    IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo,OFF
    IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5
    IDE03471-ENG117846-Vehicle configuration-remote_HMI,On
    IDE03471-ENG07589-Vehicle configuration-RSE_software_component,Deactivated
    IDE03471-ENG126143-Vehicle configuration-RVC_video_input,FBAS
    IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation,no restriction
    IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag,no_region
    IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,Not Present
    IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi,activated
    IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0
    IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold,OFF
    IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,On
    IDE03471-ENG130247-Vehicle configuration-Support_second_phone,On
    IDE03471-ENG126994-Vehicle configuration-TPEG_availability,OFF
    IDE03471-ENG06575-Vehicle configuration-UOTA,On
    IDE03471-ENG117852-Vehicle configuration-UPnP,On
    IDE03471-ENG117836-Vehicle configuration-VZAPro,OFF
    IDE03471-ENG127494-Vehicle configuration-VZO,OFF
    IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI,OFF
    IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On
    IDE03580-Country code for mobile network,0
    IDE03902-Automatic ring break diagnostic,No automatic start
    IDE04292-Roadside assistance mode,Corresponding setting in MMI
    IDE04294-Number attempted dialing attempts for roadside assistance,3
    IDE04295-Bluetooth: Preferred connection profile for phone book data,PBAP
    IDE04298-MAS01779-Vehicle dimensions-Length,0 mm
    IDE04298-MAS01780-Vehicle dimensions-Width,0 mm
    IDE04298-MAS02230-Vehicle dimensions-Height,0 mm
    IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
    IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,1
    IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,1
    IDE04521-Sporadic ring break detection,Visual
    IDE04522-Awakening ability on optical databus,OFF
    IDE04549-Telephone data services,On
    IDE04550-Bluetooth: Sniff mode,On
    IDE05111-Fee-based traffic information (TMC),65533
    IDE05113-Infotainment Recorder,activated
    IDE06697-Audio management mute function,Muting of audio sources
    IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G,0
    IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G,0
    IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
    IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
    IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
    IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
    IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
    IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
    IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
    IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
    IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
    IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
    IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
    IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
    IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
    IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
    IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
    IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
    IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
    IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
    IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
    IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
    IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
    IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
    IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
    IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,7
    IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
    IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
    IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
    IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-6
    IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-6
    IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
    IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
    IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
    IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
    IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
    IDE10480-MAS10742-Interface for external media: activation-Connection 2,activated
    IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
    IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
    IDE10668-Internal SIM card: use,Always
    IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,20 dBµV
    IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,50 dB
    IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,0.1 s
    IDE11105-Brand-specific display of connect application,de.audi.mmiconnect
    IDE11153-IDE11153-Surroundings display: virtual camera positions-,32767
    IDE11153-IDE11153-Surroundings display: virtual camera positions-,65535
    IDE11153-IDE11153-Surroundings display: virtual camera positions-,4294967295
    IDE11503-Tuner for satellite radio: preparation,05
    IDE11638-Bluetooth Audio Codec,FF
    MAS00951-Bluetooth,On
    MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
    MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
    MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
    MAS03690-Telephone,Data & language service active
    MAS03782-WLAN,On
    ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On
    ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms
    ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF
    ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms
    ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF
    ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms
    ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On
    ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms
    ENG117920-Audio_Managment_Soundset_Menu,OFF
    ENG117917-BAP_Debug_Mode_Release,not_released
    ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
    ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
    ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
    ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,n ot activated
    ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
    ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
    ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
    ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
    ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,not activated
    ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
    ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,activated
    ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
    ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
    ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,acti vated
    ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
    ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
    ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
    ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
    ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
    ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
    ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
    ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
    ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
    ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated
    ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
    ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
    ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer ,not activated
    ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
    ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_h igh,activated
    ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
    ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
    ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
    ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
    ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,no t activated
    ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
    ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
    ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_discla imer,not activated
    ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off ,not activated
    ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_thresho ld_high,not activated
    ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,n ot activated
    ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
    ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,no t activated
    ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
    ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high ,not activated
    ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
    ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
    ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
    ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
    ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,not activated
    ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
    ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
    ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,n ot activated
    ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
    ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_hig h,not activated
    ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
    ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,not activated
    ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
    ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
    ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,not activated
    ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
    ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
    ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
    ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
    ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,ac tivated
    ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
    ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,not activated
    ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
    ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
    ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,no t activated
    ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
    ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated
    ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
    ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
    ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated
    ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
    ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
    ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
    ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
    ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,a ctivated
    ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
    ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
    ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer, not activated
    ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
    ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_hi gh,activated
    ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
    ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
    ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
    ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
    ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activate d
    ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
    ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
    ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer, not activated
    ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
    ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_hi gh,activated
    ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
    ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
    ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
    ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
    ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
    ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
    ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
    ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
    ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
    ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,not activated
    ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
    ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
    ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
    ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
    ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,not activated
    ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
    ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
    ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaime r,not activated
    ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,no t activated
    ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_ high,not activated
    ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
    ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
    ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
    ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
    ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,no t activated
    ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
    ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,activated
    ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
    ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
    ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated
    ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
    ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,activated
    ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,no t activated
    ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
    ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high ,activated
    ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
    ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,activated
    ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
    ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
    ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated
    ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
    ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
    ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaime r,not activated
    ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,no t activated
    ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_ high,activated
    ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
    ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
    ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
    ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
    ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,no t activated
    ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
    ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
    ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
    ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
    ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated
    ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
    ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,activated
    ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
    ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
    ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,ac tivated
    ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
    ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
    ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaim er,not activated
    ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,n ot activated
    ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold _high,not activated
    ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
    ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
    ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
    ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
    ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated
    ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
    ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
    ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
    ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
    ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated
    ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
    ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,activated
    ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
    ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
    ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activat ed
    ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
    ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
    ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
    ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
    ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,not activated
    ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
    ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
    ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,no t activated
    ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
    ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high ,not activated
    ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
    ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
    ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
    ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
    ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,not activated
    ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,activated
    ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
    ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaime r,not activated
    ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,no t activated
    ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_ high,not activated
    ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
    ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,activated
    ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_discla imer,not activated
    ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off ,not activated
    ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_thresho ld_high,activated
    ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,n ot activated
    ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
    ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_discla imer,not activated
    ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off ,not activated
    ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_thresho ld_high,not activated
    ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,n ot activated
    ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated
    ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,n ot activated
    ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
    ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_hig h,activated
    ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
    ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
    ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
    ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
    ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,no t activated
    ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
    ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
    ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
    ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
    ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
    ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
    ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
    ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
    ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
    ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated
    ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
    ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
    ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,no t activated
    ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
    ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high ,not activated
    ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
    ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
    ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
    ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
    ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
    ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
    ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
    ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
    ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
    ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
    ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
    ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated
    ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,n ot activated
    ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
    ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_hig h,not activated
    ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
    ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
    ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,no t activated
    ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
    ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high ,not activated
    ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
    ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
    ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
    ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
    ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated
    ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
    ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,activated
    ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
    ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
    ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated
    ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
    ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,not activated
    ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
    ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
    ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,n ot activated
    ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
    ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
    ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
    ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
    ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
    ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
    ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
    ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaime r,not activated
    ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,no t activated
    ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_ high,not activated
    ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
    ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,not activated
    ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
    ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
    ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,not activated
    ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
    ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
    ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
    ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
    ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
    ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
    ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
    ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
    ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
    ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
    ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
    ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
    ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,not activated
    ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
    ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,not activated
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated
    ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
    ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated
    ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
    ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,not activated
    ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
    ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,not activated
    ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
    ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,not activated
    ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,not activated
    ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,not activated
    ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,not activated
    ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,not activated
    ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
    ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Terminal 15
    ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated
    ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Terminal 15
    ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
    ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,not activated
    ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
    ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Terminal 15
    ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
    ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,not activated
    ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
    ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Databus Infotainment
    ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
    ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated
    ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated
    ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,CAB_4
    ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,activated
    ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Databus Infotainment
    ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Terminal 15
    ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,activated
    ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,activated
    ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Databus Infotainment
    ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
    ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Terminal 15
    ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
    ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,not activated
    ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
    ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,not activated
    ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
    ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Terminal 15
    ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
    ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,not activated
    ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
    ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Terminal 15
    ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
    ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,not activated
    ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,not activated
    ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,not activated
    ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
    ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated
    ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
    ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
    ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
    ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,not activated
    ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
    ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,not activated
    ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
    ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,not activated
    ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
    ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,not activated
    ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,activated
    ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Termin al 15
    ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
    ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,not activated
    ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
    ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,not activated
    ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
    ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,not activated
    ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
    ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Terminal 15
    ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
    ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated
    ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
    ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,not activated
    ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated
    ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,not activated
    ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,activated
    ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Terminal 15
    ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
    ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Terminal 15
    ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,activated
    ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Terminal 15
    ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
    ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,not activated
    ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
    ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,not activated
    ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,activated
    ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
    ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
    ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Terminal 15
    ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated
    ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Terminal 15
    ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
    ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,not activated
    ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
    ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Terminal 15
    ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Available
    ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Terminal 15
    ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
    ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
    ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
    ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment
    ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Available
    ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Terminal 15
    ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
    ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
    ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
    ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Terminal 15
    ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF
    ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On
    ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,OFF
    ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,H264
    ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1
    ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,MOST_stream ing
    ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF
    ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264
    ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1
    ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming
    ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF
    ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_U nit-X1,0
    ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_U nit-X2,50
    ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_U nit-X3,100
    ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_U nit-Y1,0
    ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_U nit-Y2,50
    ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_U nit-Y3,100
    ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X1,0
    ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X2,100
    ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display _Unit-X3,50
    ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y1,50
    ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y2,0
    ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display _Unit-Y3,100
    ENG117915-ENG101574-Dimming_Functional_Illumination_for_Operating_Unit-X1,0
    ENG117915-ENG99557-Dimming_Functional_Illumination_for_Operating_Unit-X2,50
    ENG117915-ENG102140-Dimming_Functional_Illumination_for_Operating_Unit-X3,220
    ENG117915-ENG102936-Dimming_Functional_Illumination_for_Operating_Unit-X4,2
    ENG117915-ENG103548-Dimming_Functional_Illumination_for_Operating_Unit-X5,6
    ENG117915-ENG113992-Dimming_Functional_Illumination_for_Operating_Unit-X6,80
    ENG117915-ENG99777-Dimming_Functional_Illumination_for_Operating_Unit-Y1,10 %
    ENG117915-ENG100480-Dimming_Functional_Illumination_for_Operating_Unit-Y2,100 %
    ENG117915-ENG100773-Dimming_Functional_Illumination_for_Operating_Unit-Y3,253 %
    ENG117915-ENG100631-Dimming_Functional_Illumination_for_Operating_Unit-Y4,2 %
    ENG117915-ENG102174-Dimming_Functional_Illumination_for_Operating_Unit-Y5,10 %
    ENG117915-ENG113993-Dimming_Functional_Illumination_for_Operating_Unit-Y6,100 %
    ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
    ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,20
    ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50
    ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100
    ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150
    ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
    ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %
    ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,2 %
    ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,5 %
    ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,12 %
    ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,33 %
    ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
    ENG107658-ENG126192-mobile phone voice control availability-apple_device,not installed
    ENG107658-ENG126193-mobile phone voice control availability-other_devices,not installed
    ENG117809-p_damping_Display,5 ms
    ENG117808-p_HMI_Display,10 %
    ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
    ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
    ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0
    ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h
    Elapsed Time: 00:40
    Thankyou sir, very helpful.
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: ODBEleven 5F Adaption Map Request
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by Papereyes View Post
    Andy just emailed u the log. My car went in on Sunday so not sure if they changed the coding or not because I mentioned about sensitivity of the pre sense.
    Cheers Lai. Received
    Thanks for your help all.
    Andy
  5. Re: ODBEleven 5F Adaption Map Request
    Mar 2016
    Ipswich
    72 Post(s)
    mine does the same mate be interested to see what they find
    first time it happened I got out the car as really did beleave I'd reversed into a post and face had dropped expecting the worse
  6. Re: ODBEleven 5F Adaption Map Request
    New Forest
    80 Post(s)
    Andy I don't have ASI but can send you a map of what I do have as read by VCDS (although my VCDS is HEX+CAN
    Sent from my STV100-4 using Tapatalk
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  7. Re: ODBEleven 5F Adaption Map Request
    #17
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by ragebe View Post
    Thats fine mate. VCDS CSV is easier to get into Excel anyway
    Dont worry about dongle. 5F reads on HEX-CAN so you should be good.
    Appreciate it, cheers
    Andy
  8. Re: ODBEleven 5F Adaption Map Request
    #18
    Oct 2019
    Earth
    23 Post(s)
    @noxqzsMate do you have memory seats at least for the driver?
Page 2 of 2 FirstFirst 12
  1. Please Help 17964 fault? MAP valve (N75) & MAP sensor location ??? how to check vac lines?
    By spadders in forum Passat - B5 Forum - 1997 -2005
    Last Post: 24-03-2015, 09:55 PM
  2. Question Remote Key Adaption
    By A4 Lad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-11-2010, 01:56 PM
  3. Throttle Re-Adaption - Polo 1.4
    By Stue in forum Polo - Derby - Lupo - Fox
    Last Post: 15-08-2010, 01:15 AM
  4. Throttle body adaption really necessary?
    By Withnail in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-02-2010, 10:47 PM
  5. adaption settings???
    By robins1uk in forum VCDS - General Questions
    Last Post: 05-04-2008, 09:21 AM
