Thursday,26,January,2017,18:45:39:45799
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.1.0
Data version: 20150904
www.Ross-Tech.com
Mileage: 149780km-93068mi Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72 77
Mileage: 149780km-93068miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QD HW: 03L 907 309
Component: R4 2,0L EDC G000AG 6209
Revision: 13H10--- Serial number: VWZCZ000000000
Coding: 0000078
Shop #: WSC 84737 171 542824
VCID: 77FA4DA2067FA3866C-8022
1 Fault Found:
009754 - Coolant Pump 2
P261A - 000 - Open circuit - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 2
Fault Frequency: 255
Reset counter: 255
Mileage: 142996 km
Time Indication: 0
Date: 2011.03.14
Time: 08:36:22
Freeze Frame:
RPM: 782 /min
Speed: 0.0 km/h
Voltage: 13.53 V
Lambda: 95.5 %
Bin. Bits: 10011111
Bin. Bits: 00000000
Temperature: 35.1°C
Readiness: 1 1 0 0 1
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 052 G HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2204
Revision: 05151112 Serial number: 00001008090247
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 18386E1E2B214CFE85-804C
No fault code found.
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --026--- Serial number: 00000706167760
Coding: 0003350
VCID: 62CC0CF6BDFD562E2B-8036
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 6
Fault Frequency: 254
Reset counter: 5
Mileage: 149488 km
Time Indication: 0
Date: 2011.06.16
Time: 08:56:06
Freeze Frame:
Speed: 109.0 km/h
Hex Value: 0x0057
Voltage: 14.25 V
Bin. Bits: 00011111
Count: 214
Hex Value: 0x0000
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
Component: Climatic H14 0305
Revision: 00009001
Coding: 0000000002
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_Climatic A01005
ROD: EV_ClimaBasis_VW36.rod
VCID: 6ED468C6B125E24EBF-803A
2 Faults Found:
9479441 - Control Circuit for Front Right Seat Heater
B10A5 11 [008] - Short to Ground
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 149478 km
Date: 2017.01.22
Time: 20:33:38
9479697 - Control Circuit for Front Left Seat Heater
B10A6 11 [008] - Short to Ground
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 44
Mileage: 149478 km
Date: 2017.01.22
Time: 20:33:38
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 S HW: 3C8 937 049 S
Component: Bordnetz-SG H53 3101
Revision: 00H53000 Serial number: 00000004145862
Coding: 00888F0700041A00470A00000F000000000859435C00010000 0000000000
Shop #: WSC 05124 000 00000
VCID: 418EE37A183B2D3612-8014
Subsystem 1 - Part No: 3C2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 100810 026 0612
Coding: 00046997
Shop #: WSC 05124
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__006 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PHKWSV4
Coding: 0012342
VCID: 4C90C24E2F79F05EF1-8018
Subsystem 1 - Serial number: 6332MTS638342210
Subsystem 2 - Serial number: 6342MTS648342200
Subsystem 3 - Serial number: 6351HTS6CE54E9KJ
Subsystem 4 - Serial number: 6361HTS6M464E9KR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C9 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0136
Revision: FF010038 Serial number: 20100828300196
Coding: 1982270002
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 6FEA75C2B62FEB46B4-803A
Multi Function Steering Wheel Control Module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D
Component: E221__MFL-TK6 H06 0022
Coding: E20000
1 Fault Found:
365060 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Reset counter: 54
Mileage: 120355 km
Date: 2016.01.27
Time: 08:33:48
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C0 920 972 J HW: 3C0 920 972 J
Component: KOMBI H03 0305
Coding: 461F00
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04052
ROD: EV_Kombi_UDS_VDD_RM09_SK35.rod
VCID: 2D56AFCA7CA3D956C6-8078
Address 19: CAN Gateway Labels: 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P109070171
Coding: FD807F06400602002003
Shop #: WSC 05314 000 00000
VCID: 2F6AB5C2BEAFAB46F4-807A
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 7AFC5496356DBEEE13-802E
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0306
Revision: 13101005 Serial number: 0001395361
Coding: 0002B5
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide.rod
VCID: 65C617EA64D32116CE-8030
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001640235
Coding: 000290
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 196 3001
Revision: 00H17000
Shop #: WSC 02069 000 90108
VCID: 316EB3BAA89BBDB6E2-8064
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Coding: 0191020051030E763004941570085FCE107801
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
1 Fault Found:
00323 - Vehicle Inclination Sensor (G384)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 48
Mileage: 149665 km
Time Indication: 0
Date: 2011.06.17
Time: 18:02:19
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0306
Revision: 15101005 Serial number: 0001393564
Coding: 0002B4
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide.rod
VCID: 66C410E699D52A0EC7-8032
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001643769
Coding: 000290
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 011 Serial number: 00000000382663
Coding: 0000057
VCID: 2C50A2CE8FB9D05ED1-8078
Address 56: Radio
Cannot be reached
Address 77: Telephone (J738) Labels: 1K8-035-730.clb
Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
Component: Telefon H08 6900
Revision: 00008000 Serial number: 00000A07810344
Coding: 012120
Shop #: WSC 00671 210 95608
VCID: 2A5CA4D6454DCE6E23-807E
3 Faults Found:
01524 - Antenna for Telephone
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 120355 km
Time Indication: 0
Date: 2016.01.26
Time: 21:44:24
00446 - Function Limitation due to Under-Voltage
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 49
Mileage: 149673 km
Time Indication: 0
Date: 2011.06.18
Time: 14:52:02
02791 - Telephone baseplate (R126)
011 - Open Circuit
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 120355 km
Time Indication: 0
Date: 2016.01.26
Time: 21:44:24
End-------------------------(Elapsed Time: 02:46)--------------------------
