Re: Please help with errors –
26-01-2017,01:55 PM
Your first error is nothing to do with the stop start system. Just an intermittent error with the rear HVAC control. is it functioning properly? The second error refers to the battery monitor which is fitted to the positive terminal on the battery. have you checked the terminals and free from corrosion? Check the connection is tight and the cable that is plugged into is ok. Wiggle the wires that go to this connector and make they have not snapped/corroded even though the cable may still look attached.
RS6 Performance Ascari Blue, Carbon Ceramics Brakes and lots more.
A6 BiTdi Avant MTM
Retrofitted: Full Led Headlights, DAB, Full Electric Seats, Surround View Cameras, Genuine RS6 Grille, RS6 Seats,Leather Door Armrests, Soft Close Doors, Rear Side Blinds,High Beam Assist, Eibach Springs, Led Roof Console, 4 Zone Climate, Rear Heated Seats, Head Up Display, Side assist, Alcantara Interior Retrim
