Thread: scan code help emission light on and engine fault light
Results 1 to 8 of 8
  1. scan code help emission light on and engine fault light
    Aug 2016
    bristol
    Hi all,
    i have a 2008 passat sport saloon 2.0tdi, i had a engine fault light come on a few times in the past month and didnt think too much of it as it went out when i restarted the car. 2 weekends ago i had the VW emission scandal update applied, since then just about every journey the engine fault light bongs on and the emissions light wont go out.
    when i collected the car from VW after the emissions update the guy said they found a EGR valve fault so i thought this was the issue, i removed the EGR & throttle body cleaned them and put back on. went for a drive and still the faults were there (did drive better tho!)
    i have now done a scan and got the following issues.
    i think this is then the throttle body/anti shudder valve that needs replacing? (i have noticed sometimes it is a bit rough in stoping when i turn the engine off) shall i replace it with a new part?
    also there are a few other faults that confuse me if anyone can shed some light. 2 in the central electrics 01516 - Terminal 30; Left & 00927 - Terminal 30 (Right), the CAN BUS 01044 - Control Module Incorrectly Coded??? and the navigation not registered!
    i did fit the RNS315 radio (used) when i got the car and activated the DAB radio on the unit, if this has affected any of the issues
    Code:
    Chassis Type: 3C (3C0)Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 72
    VIN: WVWZZZ3CZ9P025405   Mileage: 205520km-127704miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Not registered 0011
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 BL    HW: 03L 907 309
       Component: R4 2.0l TDI G001SG  9977
       Revision: 13H01---    Serial number: VWZCZ000000000
       Coding: 0000072
       Shop #: WSC 00090 210 89503
       VCID: 70EF8E9B63D4E6C113-8024
    2 Faults Found:
    008466 - Throttle Actuator Control System
                   P2112 - 000 - Stuck Closed - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 2
                        Fault Frequency: 3
                        Reset counter: 255
                        Mileage: 205299 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 17:31:30
                 Freeze Frame:
                        RPM: 1587 /min
                        Speed: 25.0 km/h
                        Load: 41.6 %
                        Load: 25.5 %
                        Lambda: 87.6 %
                        Mass Air / Rev.: 690.0 mg/str
                        Temperature: 85.5C
    008465 - Throttle Actuator Control System
                   P2111 - 000 - Stuck Open - MIL ON
                 Freeze Frame:
                        Fault Status: 11100000
                        Fault Priority: 2
                        Fault Frequency: 24
                        Reset counter: 255
                        Mileage: 205017 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 16:06:27
                 Freeze Frame:
                        RPM: 1610 /min
                        Speed: 25.0 km/h
                        Load: 41.6 %
                        Load: 25.1 %
                        Lambda: 100.2 %
                        Mass Air / Rev.: 695.0 mg/str
                        Temperature: 85.5C
    Readiness: 1 1 0 0 0
    Address 03: ABS Brakes        Labels: 3C0-614-109-C4.clb
       Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
       Component: J104    C4 440 V2   0011
       Revision: --025---    Serial number: 00000785939479
       Coding: 0001298
       Shop #: WSC 00028 028 00001
       VCID: 2B5559F78A72C51966-807E
    No fault code found.
    Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
       Part No SW: 3C0 907 044 CR    HW: 3C0 907 044 CR
       Component: ClimatronicPQ46 132 0811
       Revision: 00132023    Serial number: 00000000000000
       Shop #: WSC 00000 000 00000
       VCID: 73E5819712C2DDD9EE-8026
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Part No SW: 3C8 937 049 E    HW: 3C8 937 049 E
       Component: Bordnetz-SG     H54 2602
       Revision: 00H54000    Serial number: 00000004929008
       Coding: F1800F0700041A00470A00000F00000000185D434600012C000000000000
       VCID: 3365419752429DD92E-8066
       Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
       Component: Wischer 040708 022  0601
       Coding: 00049045
       Shop #: WSC 00028
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     200808 046  0204
       Coding: 00143397
       Shop #: WSC 00028
    2 Faults Found:
                011 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00101011
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 188
                        Mileage: 205514 km
                        Time Indication: 0
                 Freeze Frame:
                            OFF
                        Voltage: 12.25 V
                            OFF
                            ON
                            OFF
                            OFF
                            OFF
                 Freeze Frame:
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 188
                        Mileage: 205514 km
                        Time Indication: 0
    Address 15: Airbags        Labels: 5N0-959-655.lbl
       Part No SW: 5N0 959 655 A    HW: 5N0 959 655 A
       Component: J234__006 VW10 HI   1815
       Revision: 19013000    Serial number: 0039DPEVTBSY
       Coding: 0012342
       VCID: 3B7569B77A125599F6-806E
       Subsystem 1 - Serial number: 6333FTS646301658
       Subsystem 2 - Serial number: 6343FTS604971548
       Subsystem 3 - Serial number: 6353ETS69TCEUVNH
       Subsystem 4 - Serial number: 6363ETS6AA2DUVNP
       Subsystem 5 - Serial number: 00000000000000000
       Subsystem 6 - Serial number: 00000000000000000
    Address 16: Steering wheel        Labels: 3C0-953-549-SW20.lbl
       Part No SW: 3C0 953 549 AB    HW: 3C0 953 549 AB
       Component: J0527               0020
       Revision: 00026000    Serial number: 3C5953507AM
       Coding: 0000013
       VCID: 6CD79AEB4FFC02212F-8038
    Address 17: Instruments        Labels: 3C0-920-xxx-17.lbl
       Part No SW: 3C0 920 960 N    HW: 3C0 920 960 N
       Component: KOMBIINSTRUMENT VD1 1216
       Revision: V0002000    Serial number: 00000000000000
       Coding: 0007405
       Shop #: WSC 39182 001 1048576
       VCID: 2E5350E3B960B03141-807A
    Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
       Part No SW: 3C0 907 530 H    HW: 3C0 907 951
       Component: J533__Gateway   H13 0142
       Revision:   H13       Serial number: 2600P0871404A7
       Coding: F9807F060002021003
       VCID: 2643A8C39190F871B9-8072
    1 Fault Found:
                000 -  -
                 Freeze Frame:
                        Fault Status: 01100000
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 135
                        Mileage: 205005 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 08:42:55
    Address 25: Immobilizer        Labels: 3C0-959-433-25.clb
       Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
       Component:    IMMO         042 0383
       Revision: 00042000    Serial number: VWZCZ000000000
       Shop #: WSC 131071 1023 2097151
       VCID: 397973BF702E6789E4-806C
       Subsystem 1 - Part No: 3C0 905 861 G
       Component:    ELV          027 0380
       3C0905861G     ELV          027 0380
    Address 37: Navigation (J794)       Labels: 1K0-035-27x-37.clb
       Part No SW: 3C0 035 279     HW: 3C0 035 279
       Component: RNS315        H05 0010
       Serial number: VWZAZ2L3317089
       Coding: 000004010400000000011000
       Shop #: WSC 00015 115 12345
       ASAM Dataset: EV_RNS315VWEUV1UDS A01005
       ROD: EV_RNS315VWEUV1UDS.rod
       VCID: 60CFFEDB7B34564183-8034
    1 Fault Found:
    1048632 - Antenna 1 for Radio
              B1119 13 [008] - Open Circuit
              Intermittent - Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 5
                        Fault Frequency: 3
                        Reset counter: 186
                        Mileage: 205303 km
                        Date: 2000.00.00
                        Time: 06:06:48
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
       Component: J386  TUER-SG FT    1518
       Revision: 72009005    Serial number: 00000760388703
       Coding: 0000693
       VCID: 6FED8DE77EEAF9390A-803A
    Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
       Part No: 1K0 909 144 C
       Component: EPS_ZFLS Kl. 195    2301
       Revision: 00H15000
       VCID: 2A5B5CF38588DC119D-807E
    Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
       Component: A_ KSG PQ46 ELV 042 0472
       Coding: 18910A0001860E7F3004941570085FCE107CA1
       Subsystem 1 - Part No: 1K0 951 605 D
       Component: LIN BACKUP HORN H08 9001
       Subsystem 2 - Part No: 3C0 951 171 C
       Component: Neigungssensor  004 0611
       Subsystem 3 - Part No: 3C0 951 171 C
       Component: Innenraumueberw.004 0611
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
       Component: J387  TUER-SG BT    1518
       Revision: 72009005    Serial number: 00000071888621
       Coding: 0000692
    Address 53: Parking Brake        Labels: 5N0-907-801.clb
       Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
       Component: J540 EPB3  VW-10498 0003
       Revision:   009       Serial number: 00000000097514
       Coding: 0000057
       VCID: 285FA6FB9B84EE018B-807C
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
       Component: J388   TUER-SG HL   0308
       Revision: 41004101    Serial number: 00000000521021
       Coding: 0000144
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
       Component: J389   TUER-SG HR   0308
       Revision: 41004101    Serial number: 00000000538888
       Coding: 0000144
       VCID: 71E98B9F68DEEFC91C-8024
    End---------------------(Elapsed Time: 01:53, udsna)-----------------------
  2. Re: scan code help emission light on and engine fault light
    Sep 2008
    SE London
    Clear all codes by going into each module.
    Shut down IGN and then exit car..
    Lock.
    Wait 10 mins for car to go into "sleep" mode.
    Re-enter and then IGN.
    Do a fresh Autscan and post here complete with the header? Delete only the VIN # if you feel you need to protect that
    The faults shown on your post are up to 500km old
    For the engine fault you could try performing the Readiness script
  3. Re: scan code help emission light on and engine fault light
    Aug 2016
    bristol
    Quote Originally Posted by RichardSEL View Post
    Lock.
    Thanks for the reply!
    I drove to work this morning and the check engine workshop light came on (not emissions) I have done what you said and there are no fault codes now ( I fixed the other as it was incorrect coding when I fitted the RNS315 I deactivated the equipment that was not installed etc)
    I will be driving home later (mix of country roads, motorway and city roads) I will do a scan when I get home and report back with a new log!
  4. Re: scan code help emission light on and engine fault light
    Aug 2016
    bristol
    ok, drove home and the engine fault light came on again stoped once and then it came back on again, stoped a second time and it didnt come back on. here is the new scan
    Code:
    Tuesday,24,January,2017,19:17:12:30709VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
    VCDS Version: 17.1.2.0 (x64)
    Data version: 20170107 DS267.0
    www.Ross-Tech.com
    VIN:    License Plate:
    Mileage: 205630km-127772mi   Repair Order: Tuesday evening
    VIN: WVWZZZ3CZ9P025405   Mileage: 205630km-127772miles
    37-Navigation -- Status: OK 0000
       Coding: 0000072
    2 Faults Found:
                   P2111 - 000 - Stuck Open - Intermittent
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 2
                        Reset counter: 255
                        Mileage: 205565 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 16:31:51
                 Freeze Frame:
                        RPM: 1794 /min
                        Speed: 78.0 km/h
                        Load: 0.0 %
                        Load: 43.1 %
                        Lambda: 100.2 %
                        Mass Air / Rev.: 330.0 mg/str
                        Temperature: 29.7C
                 Freeze Frame:
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 255
                        Mileage: 205606 km
                        Time Indication: 0
                        Date: 2000.00.00
                        Time: 17:21:14
                 Freeze Frame:
                        RPM: 1748 /min
                        Speed: 45.0 km/h
                        Load: 0.0 %
                        Load: 28.2 %
                        Lambda: 74.2 %
                        Mass Air / Rev.: 340.0 mg/str
                        Temperature: 81.9C
    Readiness: 0 0 0 0 0
       Coding: 0001298
       Coding: 00049045
       Shop #: WSC 00028
       Coding: 00143397
       Shop #: WSC 00028
       Coding: 0012342
       Coding: 0000013
       Coding: 0007405
       Coding: F9807F064002021003
       Coding: 040004010400000000011000
       Coding: 0000693
       Revision: 00H15000
       Coding: 0000692
       Coding: 0000057
       Coding: 0000144
       Coding: 0000144
    End-------------------------(Elapsed Time: 01:50)--------------------------
    sooo it does look like the throttle body to me, if you agree what is the best option, a new non-OEM part or a secondhand OEM part (both around the same price, or should i just bite the bullet and get a new OEM part at 3 times the cost?
    cheers
  5. Re: scan code help emission light on and engine fault light
    Sep 2008
    SE London
    Your fault's gone intermittent now, as your readiness code is showing all zeroes. Thus no dash icon.
    Anti-Shudder Valves do get to stick over higher miles and can benefit from a clean out.
    I'm not a Derv head but you might like to see this for the ASV and checkout the wiring first?
    Code P2112 | VW TDI forum, Audi, Porsche, and Chevy Cruze diesel forum
    Unless you know it's history, I wouldn't trust a second-hand part. And have had (as others in here
    have) had bad experiences with aftermarket "equivalent" parts. All in official looking cartons, all with
    the correct part number on.
    Advantange of VW spares' new replacement is that you'll get the latest revision part number taken from
    the latest version of ETKA when you give the clerk your VIN.
    Your Autoscan's looking good now, stay away from supermarket Derv
  6. Re: scan code help emission light on and engine fault light
    16 Post(s)
    388 Post(s)
    We fit lots of these and we try and get either VDO or Valeo.
    This happening after the update was one of the points about it I knew would come up. Cars do go wrong and there were bound to be cars that played up after the recall even though the update has nothing to do with it. You realise this but try telling someone who doesn't understand. what we call the "ever since club"
    Dark was that day when Diesel conceived his grim engine that begot you, vile invention, more vicious, more criminal than the camera even, metallic monstrosity, bale and bane of our culture, chief woe of our Commonweal. How dare the Law prohibit hashish and heroin yet license your use, who inflate all weak inferior egos? Their addicts only do harm to their own lives: you poison the lungs of the innocent, your din dithers the peaceful, and on choked roads hundreds must daily die by chance-medley. Nimble technicians, surely you should hang your heads in shame. Your wit works mighty wonders, has landed men on the Moon, replaced brains by computers, and can smithy a "smart" bomb. It is a crying scandal that you cannot take the time or be bothered to build us, what sanity knows we need, an odorless and noiseless staid little electric brougham.
    W.H. Auden (1907-1973), A Curse:
    0 2 0
  7. Re: scan code help emission light on and engine fault light
    Aug 2016
    bristol
    Ok, I wiped the codes and it was working ok for a few days with no light, now its back on with same problem. I have just purchased a new VDO throttle body and will be fitting this weekend. One question tho there seems to be mixed messages about if it is just plug in and go or if it needs setting up in VCDS?? on the new part the bag it is in says needs programming/setting up where indicated.
    Do I needs to set up in VCDS and if so how do I do this??
  8. Re: scan code help emission light on and engine fault light
    16 Post(s)
    388 Post(s)
    I like to test it in output tests and in Basic settings using the VCDS menu system.
  1. Engine management light fault code P2020/P2021
    By Caseyy in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 26-03-2016, 02:12 PM
  2. fault code v157 and engine management light on
    By pusstv in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 13-02-2015, 06:48 PM
  3. Question emission fault light
    By v6.4motion in forum Golf MK4 - 1999 - 2004
    Last Post: 18-08-2010, 10:15 PM
  4. Golf 1.8T Fault Code (Engine Management Light On)
    By Silver1.8T in forum Golf MK4 - 1999 - 2004
    Last Post: 08-04-2008, 08:21 PM
  5. Exhaust/Engine Emission Warning Light Constant Orange & EPC Light intermittent!
    By karl578 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 07-06-2007, 10:59 PM
