Thread: pleas help very poor mpg
Results 11 to 20 of 23
  1. Re: pleas help very poor mpg
    Sep 2016
    devon,tavistock
    how do i do that please bud.
    i have vcds but only one i got from ebay but i can read codes but nothing else
  2. Re: pleas help very poor mpg
    1840 Post(s)
    Engine 01, Measuring Blocks 08, Zone 001, coolant temp.
  3. Re: pleas help very poor mpg
    Sep 2016
    devon,tavistock
    hi, sorry for long delay, the temp was 88-90c. i thought i would change the stat as i never did it before but now i have no heating front or back. i tryed draining and doing again but still no heating
  4. Re: pleas help very poor mpg
    Jul 2007
    glasgow
    35 Post(s)
    run car & put the heater on the hottest setting, put the fan for the heater on full speed
    let the car run for 10 to 15 minutes and you have to make sure the temperature on dashboard is showing 90
    This is a rule of thumb for all cars, you may have use bleed nipples located at various points if fitted
  5. Re: pleas help very poor mpg
    1840 Post(s)
    Post 1998 VAG temp gauges are useless, the typical readings will be 90 at a real temperature of anywhere between 72 and 117... We were working on an A4 last week waiting for the fan to come on using the lap top to view the temp and it did not come on until 102 which is correct but the gauge still said 90.
  6. Re: pleas help very poor mpg
    Sep 2016
    devon,tavistock
    i now have heat front and back . there was a blockage is the hose going to the expansion bottle. now the gauge is moving up then back to low. but still crap on fuel.
    can the gauges read wrong and still have fuel left. the center display is flashing refuel now but fuel light not on on the gauge
  7. Re: pleas help very poor mpg
    #17
    1840 Post(s)
    Yes the two can disagree in either direction.
  8. Re: pleas help very poor mpg
    #18
    Sep 2016
    devon,tavistock
    how do i know whats right ?
  9. Re: pleas help very poor mpg
    #19
    1840 Post(s)
    You have to know where the level is in the tank and use full VCDS to help you work out what is wrong.
  10. Re: pleas help very poor mpg
    #20
    Sep 2016
    devon,tavistock
    hi, thanks for the help, seems a bit better now, secondry water pump has stopped working but new bushes in my draw just waiting for better weather. then i had a split pipe on top rad pipe. car gets warm quicker now aswell but mpg still not great. about 400 miles to full tank
  1. Poor MPG?
    By Staffylover in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 07-01-2016, 11:38 PM
  2. Please Help poor mpg
    By penvallian in forum Alhambra
    Last Post: 18-01-2011, 10:33 PM
  3. Bora 150 ARL poor running & poor mpg
    By snu in forum Bora - 1998 - 2005
    Last Post: 08-05-2010, 11:56 AM
  4. 1.8 20v adr poor power,poor mpg
    By kingfisher cab in forum Chat - Anything with wheels
    Last Post: 24-11-2008, 09:22 PM
  5. Poor Mpg
    By TUG in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-02-2008, 01:27 AM
