Thread: Crankfoam
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. Re: Crankfoam
    #21
    Jan 2017
    Australia, NSW
    Quote Originally Posted by BiscuTMonkeY View Post
    01262
  2. Re: Crankfoam
    #22
    Jan 2017
    Australia, NSW
  3. Re: Crankfoam
    #23
    Jan 2017
    Australia, NSW
  4. Re: Crankfoam
    #24
    1840 Post(s)
    What is your engine type code, AEB, AJL, ANB, APU or ARK?
    Why have you taken the Inlet Air Temp sender G42 out and posted a picture of it?
    Assuming the code 01262 is the "open to ground" version and you have no codes for Air Mass Meter, EVAP, and lambda heater then you need to check the continuity of the N75 command wire back to the ECU.
    1 1 0
  5. Re: Crankfoam
    #25
    Jan 2017
    Australia, NSW
    Oil had flowed all the way through my throttle body was wondering if cleaning that could help the problem? The original codes that showed up were
    01262
    00544-max charge air exc
    17978?
    16487-maf circuit high input
    16507- throt pos sen A cir hv input
    16515- 02 sen cir LV bank 1 sen 1
    16711- knock sen #1 cir low input
    16716 - knock sen #2 low input bank 2
    00515- camsh pos sen(hall effect sen) shrt B+ (g40)
    00670 - thrt pos sen G127
    After clearing codes
    01262
    Keeps returning when scanning engine
  6. Re: Crankfoam
    #26
    Jan 2017
    Australia, NSW
    01262
    17978?
    01262
    Didnt write properly for obvious reasons
  7. Re: Crankfoam
    #27
    Jan 2017
    Australia, NSW
    Also seen exactally this on youtube today
  8. Re: Crankfoam
    #28
    1840 Post(s)
    I need your engines type code, AEB, AJL, ANB, APU or ARK, not the fault codes.
    1 1 0
  9. Re: Crankfoam
    #29
    Jan 2017
    Australia, NSW
    Check pm
  10. Re: Crankfoam
    #30
    1840 Post(s)
    It has an AJL engine (132Kw), DWR box, a DAJ final drive, it is a type 8D2 0G5 and was built 15.07.1999 and is a 2000 model year.
    You need to check the continuity of the yellow/white wire from pin 2 on the N75 plug back to pin 64 on the ECU plug.
    With the fuel pump running, pin 1 on the N75 (red/green) should have battery voltage.
    1 1 0
