Thread: Crankfoam
Results 11 to 20 of 39
  1. Re: Crankfoam
    Jan 2017
    Australia, NSW
    Personally I would use brake cleaner as it evaporates quickly. Yes, disconnected the coil packs from their power stops them generating a spark which could be interesting with volatile chemicals around plus they do not like being triggered when they aren't installed, it can make them fail, which is annoying.
    Have done throttle body cleaner loosened alot of stale oil but replace sparks still no start
    https://www.youtube.com/channel/UCAm...xsipOOyGVpVsHw
    https://www.twitch.tv/biscutmonkey
    Twitter BiscuTMonkeY
  2. Re: Crankfoam
    1841 Post(s)
    You need to check for a spark and this means each plug must be soundly earthed to prevent damage to the coil pack. Even then you can get a spark from a faulty coil pack in the open atmosphere but once under compression in the cylinder at 14Bar, the spark will not ionize and jump the gap. Are you sure fuel is being injected?
  3. Re: Crankfoam
    Jan 2017
    Australia, NSW
    Checking the injectors today
  4. Re: Crankfoam
    Jan 2017
    Australia, NSW
    Codes
    01262
    00544
    16487
    16507
    16515
    16711
    16716
    00515
    00670
    I know what the codes are and judging by what ive seen i need to replace? The wastage bypass regulator valve or just check? And my camshaft position sensor is gone or i need a new distributor?
    Twitch
  5. Re: Crankfoam
    1841 Post(s)
    The can't all be permanent codes.
    What is the cars engine type code?
    1 1 0
  6. Re: Crankfoam
    Jan 2017
    Australia, NSW
    16507
    01262
    After erasing codes
    These come back continually
  7. Re: Crankfoam
    #17
    1841 Post(s)
    00670 - Throttle Position Sensor (G127)
    This can be “Signal too Low”, “signal too high” or “Implausible signal
    You need to state which it is
    16507 - Throttle Position Sensor (G69): Signal too High
    01262 - Solenoid Valve for Boost Pressure Control (N75)
    This can be “Short to Ground”, “Short to plus” or “output open
    Again you need to say which it is
    1 1 0
  8. Re: Crankfoam
    #18
    Jan 2017
    Australia, NSW
    It was to ground i have sorted that, codes erased start again comes back wastage bypass regulator valve pulled throttle body off oil all through it will clean up but this isnt going to cause the car not to start is it?
  9. Re: Crankfoam
    #19
    1841 Post(s)
    What is the code number?
    1 1 0
  10. Re: Crankfoam
    #20
    Jan 2017
    Australia, NSW
    01262
