Thread: Camshaft Position Sensor issue
Results 1 to 10 of 12
  1. Camshaft Position Sensor issue
    Jan 2017
    north Africa
    hi all
    engine difficult to start engine cold or warm same thing
    erratic idling at first star then after while normal idling
    hesitation when accelerating
    when accelerate hard its sounds like shocking no response at hard acceleration
    poor engine response poor engine performance
    trouble cods
    P0341 Camshaft Position Sensor CircuitRange/Performance 004 No Signal/Communication
    sensor convector unplugged
    p0343 Camshaft Position Sensor high input
    ????????? help
    a4 b6 2003 2.0 alt engine
  2. Re: Camshaft Position Sensor issue
    Pembrokeshire
    22 Post(s)
    maybe start with a new cam sensor.
  3. Re: Camshaft Position Sensor issue
    1841 Post(s)
    Is it plugged in? It is right under your nose when you open the bonnet.
  4. Re: Camshaft Position Sensor issue
    Jan 2017
    north Africa
    yes it plugged in sam code p0341 unplugged p0341
  5. Re: Camshaft Position Sensor issue
    Jan 2017
    north Africa
    replaced the sensor same issue
  6. Re: Camshaft Position Sensor issue
    1841 Post(s)
    Check for 5v engine running across the plugs pins 1 and 3, red/black and black.
  7. Re: Camshaft Position Sensor issue
    Jan 2017
    north Africa
    i used testing device has 5v lamp and 12v lamp i did check the pins 1 & 3 output 5v lamp on
  8. Re: Camshaft Position Sensor issue
    Jan 2017
    north Africa
    some one told me that maybe there is play movement in intake cam shaft adjuster makes camshaft ruing off timing
  9. Re: Camshaft Position Sensor issue
    1841 Post(s)
    The fault looks to be electrical but it is the AWA engine which suffers from problems with the mechanical side of the VVT, the ALT is much more reliable. You need to check the signal of the G40 at the ECU.
  10. Re: Camshaft Position Sensor issue
    Jan 2017
    north Africa
    thanks man for your replays
    today got new code after long driving P1340 Crankshaft position sensor and camshaft position sensor not corresponded
    002 Lower Limit Exceeded
    and new symptom
    during driving at steady speed the car like cut off not staling but suddenly cut off it wont accelerate any more till i release my foot on the accelerator paddle and push accelerate again
  1. Golf Match TDI 105 Camshaft Position Sensor issue
    By Dermottc in forum Golf MK5 - 2004 - 2009
    Last Post: 06-09-2016, 03:34 PM
  2. Camshaft position sensor / sender (G40 Hall sensor) replacement Audi A6 2.0 BRE
    By Strath44 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 19-05-2016, 02:26 PM
  3. Replies: 3
    Last Post: 26-05-2011, 12:07 PM
  4. Please Help Camshaft Position Sensor
    By stephan in forum Touran - Sharan - Caravelle
    Last Post: 06-09-2010, 09:38 PM
  5. Replies: 8
    Last Post: 07-02-2009, 11:21 PM
