Thread: Park Brake Release
  1. Park Brake Release
    Cornwall
    Hello all,
    I have an issue that I am trying to address with my parking brake.
    When released, the brake lever seems to jam due to the cable bending. Is there a return spring in the system anywhere, that should pull the cable back when the lever is released?
    I am aware of the gas strut problem and have already replaced this. In doing so, I have found this new problem.
    Does the transfer module have an internal spring or are the springs in the drum mechanism the only ones? Seems like sticking in the system somewhere, but a readjustment might bring things back in.
  2. Re: Park Brake Release
    Cornwall
    Sorted.
    The transfer module had jammed due to corrosion and lack of use. Once freed up, the cable could be correctly adjusted and the slack taken out of the cable. The gas strut can now correctly operate the pedal and therefore the switch.
  3. Re: Park Brake Release
    May 2017
    Bromley
    Where does this adjust as mine stops half way and I have to lift it with my foot?
  1. Park brake Malfunction
    By CoNmac in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-06-2013, 10:24 PM
  2. Please Help passat b6 park brake
    By haggis1972 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 22-04-2012, 04:27 PM
  3. Electric park brake strip down
    By martin1810 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-11-2010, 01:13 AM
  4. Park Brake would not release!!!
    By Baldone in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-12-2008, 09:50 AM
