Thread: Main/High beam not working, HELP!!
  1. Main/High beam not working, HELP!!
    Nov 2016
    Right so, noticed the other night my main beams would not turn on or flash, nothing! So checked bulbs, flipped them over on to the dipped and they worked , so bulbs are not the issue! Hooked the diagnostic up and get the error message below :
    Central electronics
    Part #: 8K0907063
    Coding: 690050B10014B7000001000000005F5F001D02080000014100 0000 (hex)
    Component: BCM1 1.0
    Fault codes:
    01495 Bulb for High-Beams, Left (M30)
    Checked Ross tech and it relates to the bulbs and connections on the harness, all seem good. What could be causing this???
  2. Re: Main/High beam not working, HELP!!
    Oct 2012
    Estonia
    64 Post(s)
    Now swap xenon modules between left and right, could be the issue!
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+(With Street view) Other Stuff: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, Basic sound to Audi SS + B/O sub/tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Efficiency prog via cluster & gateway flash...
  3. Re: Main/High beam not working, HELP!!
    Nov 2016
    There halogens not xenons :-/
  4. Re: Main/High beam not working, HELP!!
    Oct 2012
    Estonia
    64 Post(s)
    ok.
    In that case, maybe main connector on the light one pin is burned out in the middle so to say, or wiring connector pin is burned out or module j519 itself has fault etc!
  5. Re: Main/High beam not working, HELP!!
    Nov 2016
    Anyone have a fix for this ?
  1. Please Help Getting Main beam fault on dash even though lights are working fine
    By Jatt_ in forum A8 - S8 - V8
    Last Post: 15-05-2014, 12:16 PM
  2. A6 Main Beam
    By stevedrinnan in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-11-2010, 09:01 PM
  3. No main beam...
    By DukesA6 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-03-2010, 12:45 PM
  4. Brake lights and main beam not working!
    By mattyc94 in forum 80 - 90
    Last Post: 24-12-2008, 11:55 PM
  5. Near SIde Main Beam STopped Working
    By markb1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-05-2007, 10:21 AM
