Thread: Fuel gauge calibration for 54 litre tank
Results 1 to 10 of 14
  1. Question Fuel gauge calibration for 54 litre tank
    Jan 2017
    Walsall
    Just getting to know my A4 (S line 190 S tronic) since getting it in December and wondered if anyone else has one with the larger 54 litre fuel tank but struggles to get anywhere near that much fuel in it?
    For instance, I filled it up from a quarter full and it only took about 35litres, was expecting more like 40 (0.75 x 54) so I thought I'll let it get lower next time.
    So I let it get to when the red light comes on and you keep getting messages about being dangerously low on fuel, and can it take you to the nearest fuel station etc. and then I filled it up again. This time it took about 43 litres, so still 11 in the tank presumably!
    This seems like the gauge is unnecessarily cautious. Obviously some safety factor is good, as you wouldn't want to run out the moment it indicated empty, and I would never let it get that low in any case,
    but it just seems that in order to take advantage of the larger tank you would have to drive with constant low-fuel warning lights on and reminders all the time, which would obviously discourage this.
    I was expecting the red light to come on the gauge when there was about 6 litres left, still enough for 50-60 miles, although they would perhaps be tense miles! The other issue with this is the fuel gauge is a digital led segment thing, lovely to look at and all that but not so practical. The segments stay lit for quite a while then a whole chunk goes, unlike with an analogue gauge where you can judge it more precisely and have more of an accurate idea of remaining fuel.
    I should point out I am adjusting from a previous B8 A4 with a 63litre tank, and I fairly often do long journeys so a decent range is a must, hence why I wanted the 54litre tank in the new one and not the comedy 40litre!
  2. Re: Fuel gauge calibration for 54 litre tank
    Feb 2010
    In the middle
    I have found exactly the same with my A4 (with larger fuel tank). When the display shows I have a range of less than 50 miles, the tank more than often only takes approx 45 litres to fill. In 27k miles, I have only twice had to put over 50 litres in the car and once managed to squeeze 54 litres into it (I must have been feeling very brave that week).
    A4 (B9) Ultra Sport. 150ps Diesel S-tronic. Glacier White
  3. Re: Fuel gauge calibration for 54 litre tank
    Jan 2017
    Walsall
    You're way braver than me then to get upwards of 50 litres into it! Even 54...the range must have been in single digits...
  4. Re: Fuel gauge calibration for 54 litre tank
    Feb 2010
    In the middle
    Quote Originally Posted by jds68 View Post
    It was flashing at me a fair bit and I couldn't cancel the warning! Think it said zero range for about 20 miles before I re-filled it. I do like playing fuel gauge roulette ;-)
  5. Re: Fuel gauge calibration for 54 litre tank
    Nov 2013
    Uddersfield, England
    I have the 54 litre tank but haven't refilled from empty yet, but what I have noticed is that the range when full is only about 350 miles. I will monitor and report back
  6. Re: Fuel gauge calibration for 54 litre tank
    Jan 2017
    Walsall
    Your long term trip computer will give you the average mpg, but in any case if you only have 350 miles range at full on 54 litres that's only about 29.5 mpg!
  7. Re: Fuel gauge calibration for 54 litre tank
    Feb 2010
    In the middle
    For info, I generally get approx 550 - 600 miles per tank with an Stronic 2.0 diesel. Roughly 53 mpg (see fuelly link below).
  8. Re: Fuel gauge calibration for 54 litre tank
    Jan 2017
    Walsall
    Currently I'm getting more like 50 average, range on fill up says about the same as xtremist - also a 2.0 diesel s tronic.
    All depends on what type of traffic/roads and how you drive. I always find the winter is the worst time of year for everything to do with driving, especially economy though!
  9. Fuel gauge calibration for 54 litre tank
    Nov 2013
    600 ish miles on the clock and the long term readout is showing mid 40's mpg. I filled it up today and the miles to empty was showing 510, so I guess this improving as the car has more history to work from and the mpg improves
    My commute home was 51 mpg
  10. Re: Fuel gauge calibration for 54 litre tank
    Jun 2008
    The range is based on more recent driving, rather than the long-term average. I can't find a figure in the manual but for the B8 it was the last 30km. My range on filling up generally varies from about 500-565 because of this but sometimes dips if I've spent a lot of time stuck in traffic, especially with a cold engine
    Audi A4 (B9) Avant 3.0 TDI (272) Quattro with lots of toys
  1. New Q7 85 litre fuel tank
    By JMB7 in forum Q7 - 4M Forum - 2016 -
    Last Post: 29-12-2015, 01:40 PM
  2. diesel tank leaking fuel out everywhere underneath car ??? any know tank problems
    By dazbo1972 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-09-2014, 10:50 PM
  3. Fuel tank/gauge
    By JustinM3 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 15-08-2011, 01:57 AM
  4. Save upto 1 litre of fuel per tank
    By rapport25 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 28-07-2010, 09:34 PM
  5. Bora Fuel gauge reading full on empty tank
    By cubby in forum Bora - 1998 - 2005
    Last Post: 06-06-2006, 06:15 PM
