Thread: winter engine temp raise slowly in my case? T-stat stuck at open?
  1. Question winter engine temp raise slowly in my case? T-stat stuck at open?
    Jan 2013
    Liverpool
    Hi all, I am VW's fan. 2007 passat B6 diesel 130k mileage. Every morning in winter, same driving route.
    the outside temperature is 0 degree centigrade (32F).
    I have to drive 2.2 miles and 10min and then the gauge start to move from the bottom.
    And then continue to drive on motorway up to 12miles and 20min. The gauge reach the 90 degree centigrade (190F). At the moment, if I turn on the heater fan in the car, the temp will drop to 80C. Until driving more 10 min. , the final temp reach 90C(190F)
    I feel the coolant temp raise too slowly. If I compare with my golf 2010 MK6 diesel.
    All of condition are same. But only after 1.5 miles and 5min, the gauge start to move from the bottom. and then 3.5miles and 7min driving on motorway, gauge can raise to 90 degree centigrade (190F).
    do you think that thermostat of my passat B6 stuck at open status?
  2. Re: winter engine temp raise slowly in my case? T-stat stuck at open?
    SE London
    Yes, because your temp gauge falls when you switch on heater.
    Thermostat change. Flush out old coolant. Back flush if possible.
    Fill with fresh G12, G12+, or G13 50% diluted with boiled water (to get some of the chalk out)
    Or better use de-ionised water.
  3. Re: winter engine temp raise slowly in my case? T-stat stuck at open?
    glasgow
    35 Post(s)
    or buy it pre mixed , even better
    he has the same thread going in golf forum
  4. Re: winter engine temp raise slowly in my case? T-stat stuck at open?
    SE London
    I didn't know that the VW spec anti-freeze could be bought pre-mixed?
    Is that to 50/50?
  5. Re: winter engine temp raise slowly in my case? T-stat stuck at open?
    glasgow
    35 Post(s)
    I use Triple QX Red anti freeze from euro car parts
    you have the option of buying concentrated or ready mixed
    if you go in with the specs you need, you can check it out, I am sure Halfords must have it on the shelf
  6. Re: winter engine temp raise slowly in my case? T-stat stuck at open?
    Jan 2017
    GB
    My mk4 golf does this ever since coolant flush but its more that after its reached 90'.. While driving the temp drops. Could it be the temp sender too? And is this a common after a coolant flush?
    Sent from my D5503 using Tapatalk
  1. Am I risking engine damage with the turbo veins stuck open?
    By mikeote in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-01-2017, 06:24 PM
  2. GT Stat.Audi Remote Stat
    By HAWKS in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 27-05-2013, 05:42 PM
  3. Question Exhaust or maybe fuel smell that is heavy when car windows are open and driving slowly or idling.
    By christine33 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-07-2012, 09:42 PM
  4. Engine turns over very slowly.....
    By Indie in forum Golf MK3 - 1993 - 1999
    Last Post: 17-12-2009, 12:34 PM
  5. A42.0 Alt Engine T/stat
    By malcolm tripp in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-01-2008, 05:01 PM
