Thread: AWX Cambelt Change
Results 1 to 8 of 8
  1. AWX Cambelt Change
    Aug 2009
    Olney, Uk
    Does anybody know if it os possible to change the cam-belt on a c5 A6 (AWX) by just removing the radiator and gaining access this way, or is bringing the front end into the service position the only real way of doing it?
    Many thanks.
  2. Re: AWX Cambelt Change
    May 2015
    Kirmington, North Lincolnshire
    Havn't done it myself but....
    Did have the front off to change the radiator and electric fan.
    Looking behind there I was contemplating the belt change as mine is nearly ready for it. I'd say really just no, for the 20 minutes or so it takes to pull the front or remove it, I would just remove it.
    Fog lights out, securing bolts out, lift the sides off their clips and thats about it - really is that easy.
    2003 Audi A6 Avant 1.9 tdi Sport
    0 2 0
  3. Re: AWX Cambelt Change
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I've done belts and pumps on a few AWX B 5 passats, not sure if there is much difference in room on an A6 ( I doubt it) but I reckon the grief you'd have trying to get in there without being in the service position would not be worth it vs. the bit extra work in moving the front forwards, or better still remove the lock carrier completely and swing the AC condenser round out the way on the hoses. This gives you full on access for doing the pump, setting belt tension etc. unless you pay yourself by the hour, take the bit extra time to get the main belt / pump job done better!
    0 2 0
  4. Re: AWX Cambelt Change
    Pembrokeshire
    22 Post(s)
    why would you even bother messing about taking just the rad out when the car is designed to have the front removed to make a belt change so easy. i have watched people struggle like crazy, so easy to pull the front off.
    1 2 0
  5. Re: AWX Cambelt Change
    Feb 2016
    Must agree with zollaf, service position any day of the week... takes about 45 min to get the car in the this position, home on your back.. I done the cambelt on my 2003 AWX in November... took just over 4hour and that included a lunch break, YES home on my back...
    0 2 0
  6. Re: AWX Cambelt Change
    Aug 2009
    Olney, Uk
    If it's that easy and quick to get into the service position the I totally agree. Wasn't challenging, just wondering, having looked at the more open slam panel design relative to my previous Passat B5. Thanks for the feedback.
    1 1 0
  7. Re: AWX Cambelt Change
    Feb 2016
    To be honest, the first time I done it... I made it really hard work... just take your wheels off as well as the plastic inner wing trims.. six torq screws on the slam panel, three nuts on each side under the headlamps, two long vertical bolts holding the bumper bolts.. slide in two its of bar, or in my case a longbar and torque wrench and edge the bumper back.
    I think that it
  8. Re: AWX Cambelt Change
    Aug 2009
    Olney, Uk
    Quote Originally Posted by dablade View Post
    I think that it
    Thanks, if its that simple. No debate! Looking forward to getting started.
  1. Question 2005 A6 C5 Avant 130 tdi (AWX) Clutch Change
    By Brownieaj in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-01-2017, 12:25 AM
  2. A4 1.9tdi 130 Cambelt change Do I need to change hydraulic tensioner
    By warriorsage in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-02-2015, 09:43 AM
  3. 1.9 tdi (AWX) cambelt replace DIY or not?
    By Dave Avant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-07-2013, 04:09 PM
  4. How To AWX thermostat change
    By portovechios in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-06-2013, 09:08 PM
  5. Cambelt change and auto gearbox oil change
    By shabazmo in forum Golf MK4 - 1999 - 2004
    Last Post: 26-10-2008, 11:53 AM
