Thread: Clutch pedal vibration
Results 1 to 9 of 9
  1. Clutch pedal vibration
    Jan 2016
    manchester
    Hello all
    Hopefully someone can give me some advice
    I have owned my a3 2.0 tdi for over a year and when I bought it the clutch pedal had a slight vibration but over time I think it has got worse .
    If you push your foot down slightly on the pedal you can feel it and it gets worse when you rev the engine this is when it's in neutral , is this a clutch problem or could it be something else ?
    Any advice would be greatly appreciated
  2. Re: Clutch pedal vibration
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    It could be a number of clutch assy. issues, such as release bearing, clutch cover... either way, the box needs to come out to investigate.
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Clutch pedal vibration
    Jan 2016
    manchester
    Hello alan02
    Thanks for your reply
    Is this a big job ?
    If so while the box is out would you change the clutch and flywheel or just the offending part ?
  4. Re: Clutch pedal vibration
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    You'll probably find the flywheel is the offending part and would be mad not to change the whole lot while the box is off.
  5. Re: Clutch pedal vibration
    Jan 2016
    manchester
    Hell rob69
    Thanks for your help
    Thought there would be some sort of noise if it was the flywheel
    I can't hear any noise just vibration on the pedal
  6. Re: Clutch pedal vibration
    Nov 2010
    104 Post(s)
    Who knows until you get in there!! are you going to chance not replacing it though??
  7. Re: Clutch pedal vibration
    Jan 2016
    manchester
    Cheers for you help
    Do any of you have any idea of cost for new clutch and flywheel , I've seen a lSachs for £340 on eBay for both but I have no idea of labour cost
    Anyone have any idea ?
  8. Re: Clutch pedal vibration
    Oct 2020
    Uk
    Quote Originally Posted by bertb View Post
    Hello all
    Hi there I have exactly the same issue after getting the clutch and flywheel replaced 6 weeks ago took it to audi today they said nothing wrong with the clutch or no vibration
  9. Re: Clutch pedal vibration
    Oct 2020
    Uk
    Quote Originally Posted by Alper1991 View Post
    I see. Well I went back up there they said the same so I booked another appointment with audi elsewhere to get it checked with them. Clearly there is a slight vibration on the pedal disappears half way down and comes back a little at the bottom but more vibration as you rest your foot on the pedal
  1. Please Help Clutch pedal vibration.
    By underthealders in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-04-2015, 09:47 PM
  2. Vibration through clutch pedal
    By mobitune in forum Chat - Anything with wheels
    Last Post: 01-09-2009, 03:00 PM
  3. Please Help Clutch pedal vibration on gear change
    By M4N1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 20-04-2009, 10:19 AM
  4. Please Help Vibration through clutch pedal.
    By the surfer in forum Golf MK5 - 2004 - 2009
    Last Post: 13-12-2008, 08:07 PM
  5. Noise and Vibration through clutch pedal after starting
    By tonyyeb in forum Golf MK5 - 2004 - 2009
    Last Post: 24-04-2008, 03:58 PM
