Thread: Refit sump sound deadening
  1. Refit sump sound deadening
    Aug 2012
    East Sussex
    The moulded sound deadening cover has come loose from one end of the sump of the AWX engine in my B5.5 Passat TDi and is flapping around. Has anyone else had this problem and been able to fix it? Do I need to get the car up on a lift to fix it or is access possible from ground level?
    Any suggestions much appreciated.
  2. Re: Refit sump sound deadening
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    I got my b5.5 2 1/2 years ago and during first service found the same problem. i just removed it completely while draining the oil. no detrimental effects noticed! I usually run the car up on front ramps to get enough clearance to drop the undertray off. I've had to renew the half turn screws and clips for the undertray but got a load off ebay cheap enough.
  3. Re: Refit sump sound deadening
    Aug 2012
    East Sussex
    Thanks Rob69. I had some old ramps but had to scrap them because they would have clouted the front bumper. As a result I have to make do with the small clearance under the car to get the under tray off. Did you buy ramps with a shallower angle? If so I would be interested to know what make/type and where from.
  4. Re: Refit sump sound deadening
    Nov 2010
    104 Post(s)
    You're right - the passat has a long front end overhang, i made a set of shallow angle ramps, not very high but enough to get underneath.
    what about these - need to check the angle though!
    http://www.ebay.co.uk/itm/HEAVY-DUTY...0AAOSwBLlVba4i
  1. Sound deadening material part number for spare wheel well
    By warp_speed in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 19-09-2011, 04:45 PM
  2. Replies: 2
    Last Post: 10-04-2011, 08:54 PM
  3. Road Noise and Sound Deadening
    By MeAudi in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 27-07-2009, 10:55 AM
  4. Question Tyre Roar and Sound Deadening -Audi A3
    By Openskyz in forum Audi A3 - Archive Topics
    Last Post: 09-03-2009, 10:56 PM
  5. Sound deadening!!!!
    By ss.raju-golf4 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 03:05 PM
