Thread: 2014 A4 Clutch Judder?
  1. 2014 A4 Clutch Judder?
    Jan 2017
    london
    hi
    i have just bought my first Audi which is an 2014 A4 2.0 TDI (150) black edition with just over 9000 miles.
    I have a question about the clutch as it sometimes judders when pulling away in first.
    I have also noticed that sometimes when you take the car out of gear into neutral, when you lift the clutch, the revs pick up slightly and then drop to normal idle revs. This doesn't happen all the time so it leads me to think there is an issue, or is it just a characteristic?
    this is my first Audi so not to sure what i should expect. I have tried to book it into a dealer but they never call back and i am constantly chasing. I have tried 3 dealers, chingford, hatfield and hitchin.
    Any help/ advice would be appreciated!!
  2. Re: 2014 A4 Clutch Judder?
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Hi, the rev issue is normal. The ECU gets a signal from the clutch switch when it is operated. The judder needs looking at. It could be oil on the Plate, DMF or faulty clutch. Try booking on-line?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: 2014 A4 Clutch Judder?
    Jan 2017
    london
    Thanks alan, I think i will have to physically turn up to book it in. I have emailed, phoned & done the online chat. Seems from reviews that audi dealers are very poor at aftersales.
    I am in north london and have contacted 3 different ones with no joy.
    Any recomendations for a good dealer?
    Only had the car for 4 months. I bought it from Swansea Audi which were really good, but long way to go for a check up!
  4. Re: 2014 A4 Clutch Judder?
    Jul 2008
    Never had a problem with Audi dealership in Watford. Might be worth a call.
  5. Re: 2014 A4 Clutch Judder?
    Jan 2014
    I had a similar problem with my 2014 B8 Black edition. The judder was more pronounced some times.
    Dealership had car in to remove gearbox and check out clutch etc.
    Fault was found to be distorted springs on the pressure plate.
    Plate was replaced and all is back to normal
    Before - 2008 A4 2.0 TDI SE 143 PS Silver
    Before - 2014 A4 2.0 TDI 150 PS BE in Phantom Black, Tech Pack
    Present - VW Tiguan R-Line 150 PS in Deep Black Pearl
  1. 2014 S3 saloon clutch problems
    By Scott.s3.saloon in forum Audi A3 - 8V - 2012 - 2016
    Last Post: 10-09-2015, 09:44 AM
  2. clutch judder
    By waynetdi130 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 25-07-2014, 05:10 PM
  3. Please Help intermittent clutch judder with new clutch & flywheel
    By FLENG2008 in forum Golf MK5 - 2004 - 2009
    Last Post: 15-01-2013, 03:48 PM
  4. Clutch Judder
    By e6m6a6 in forum Octavia
    Last Post: 09-11-2011, 10:14 PM
  5. judder from clutch
    By dazzer07 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 25-01-2009, 04:11 PM
