Thread: Replacing door puddle lights
  1. Replacing door puddle lights
    Dec 2016
    KENT
    I've got some replacement led door lights. When I went to remove one of the door lights (white one under door) I pulled it out and the cable disconnected. The problem I have is the cable is too short to reconnect it. I can grab it with my fingers through the hole but it won't come out long enough to reattach.
    Has anyone else had this problem. If so is there any way of fixing this? Do I have to take the door panel off?
  2. Re: Replacing door puddle lights
    Oct 2010
    rainham kent
    They are really tight but a slight pull to reconnect will be fine. Failing that pull the door card off (once you've undone the torx screws) and re route the cable as it'll be directed a certain route to give you more slack.
  3. Re: Replacing door puddle lights
    Dec 2016
    KENT
    Ok thanks. I ended up taking the door card off to get the wire out enough to reconnect.
  1. A4 saloon fitting red door and puddle lights
    By Dublandy in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-12-2012, 11:32 PM
  2. Help needed A4 door/ puddle lights
    By grabread in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 23-07-2012, 07:55 PM
  3. Replies: 4
    Last Post: 01-06-2010, 08:32 PM
  4. Door warning lights and puddle lights retro fit
    By PNS2007 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2010, 10:18 PM
  5. Rear door warning/puddle lights
    By andy4795 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-01-2010, 11:39 PM
