Thread: Swapped plugs and leads. No won't fire
Results 1 to 10 of 14
  1. Swapped plugs and leads. No won't fire
    Jan 2017
    wirral
    Hi all. Just swapped plugs and leads on my 2.0 cabbie. Done each lead one by one so I didn't mess anything up. Car started ok. Got to the 4th plug. Would not move at all. Left it but swapped the lead. Now the car started running quite lumpy. I'd put your foot down and she would jump down the road. Now she wont start at all. Really.confused.. any help much appreciated
  2. Re: Swapped plugs and leads. No won't fire
    Jul 2015
    Staffs
    46 Post(s)
    Did you gap the plugs? What plugs did you use? Try removing the stuck plug with the engine hot.
    Ian
    A4 B6 Avant Nogaro Blue
  3. Re: Swapped plugs and leads. Now won't fire
    Jan 2017
    wirral
    Yeah plugs are spot on. Can't get the engine running to get it got to remove the stuck plug tho. I bought bosch ones.
  4. Re: Swapped plugs and leads. Now won't fire
    1840 Post(s)
    Which year and engine code is your car?
  5. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    wirral
    It's 1999. Euro car parts said it was a 2000 haven't a clue what engine code is sorry. How do I find out
  6. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    camberley
    check your logbook , engine code will be the first few letters of the engine number . or look for plate under the engine / sticker in spare wheel well . should be 3 letters
    Ps I've had loads of trouble with bosch plugs and leads lately . especially euros supplied ones , I insist upon ngk plugs every time and check their catalogue myself before purchasing .
  7. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    wirral
    Engine no AGG
  8. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    camberley
    has this engine got the single coil pack ? think it has , check it is earthed properly . if you were getting spark issues before changing the plugs and leads could possibly be this coil pack . had it happen lots back in the day .
  9. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    wirral
    Yes it has.wasn't really.getting an issue before hand. Just changing as not been done in a while.
  10. Re: Swapped plugs and leads. No won't fire
    Jan 2017
    camberley
    i think the back of the coil pack is its earth , so maybe clean that up and try again . and re check the leads and plugs have got all the right connectors and are pushed home all the way . sounds silly i know but new leads can be a lot tighter to push on . if all was fine before its got to be a simple one to fix
  1. plugs and leads?
    By clive30v in forum Chat - Anything with wheels
    Last Post: 03-08-2009, 06:32 PM
  2. changing ht leads and spark plugs on mk4 golf GTI
    By k dawg in forum Golf MK4 - 1999 - 2004
    Last Post: 10-10-2008, 10:12 AM
  3. How long do plugs and leads last?
    By meathead in forum Golf MK4 - 1999 - 2004
    Last Post: 02-08-2008, 12:10 AM
  4. Spark Plugs and Ignition Leads
    By andy_c_v in forum Golf MK4 - 1999 - 2004
    Last Post: 30-05-2008, 05:36 PM
  5. Audi Missed Recall On A6 Leads To Fire
    By loyal in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 07-06-2007, 06:18 PM
