Thread: bricked mmi 3g unit
Results 1 to 10 of 10
  1. bricked mmi 3g unit
    Feb 2015
    Sweden
    I wonder if anyone could help me reprogram my bricked mmi 3g unit?
    Regards
  2. Re: bricked mmi 3g unit
    May 2014
    Darlington
    45 Post(s)
    Can you give us an idea of how you bricked it? As there are solutions to get the firmware back on.
  3. Re: bricked mmi 3g unit
    Feb 2015
    Sweden
    To be totalt honest I bought it "broken" from ebay and are now trying to get it to work again.
    I have followed some guides on the internet where i have soldered me an serial port on the card edge connector. So I can se mmi booting up and I can launch the MMI3G EmApp.
    Every flashing programs success but when it comes to start it up it always failed.
    I downloaded the hnav_eu_k0257_5 and put it on a sdcard.
    My last try was now to replace the harddrive whit an similar 40gb
    Then I set up the new partitions according to this guide;
    DIY: Upgrade MMI 3G HDD to SSD
    And then i run these commands, to reinstall the flįsh memory cards.
    flashit -a 0x00040000 -d -f /mnt/sdcard10t11/3/MU9308/fpga/41/default/SystemFPGA.hbbin
    flashit -a 0x00100000 -d -f /mnt/sdcard10t11/3/MU9308/fpga-emg/41/default/SystemFPGA.hbbin flashit -a 0x001C0000 -d -f /mnt/sdcard10t11/3/MU9308/ifs-emg/41/default/ifs-emg.ifs
    flashit -a 0x00780000 -d -f /mnt/sdcard10t11/3/MU9308/ifs-root/41/default/ifs-root.ifs
    flashit -a 0x04E00000 -d -f /mnt/sdcard10t11/3/MU9308/efs-system/41/default/efs-system.efs
    flashit -a 0x06200000 -d -f /mnt/sdcard10t11/3/MU9308/efs-persist/41/default/efs-persist.efs
    Now when I start the unit up it fails with this lines;
    Duration of starting JDSIBundle : 5572ms
    ##### Error caught in event loop: java.lang.ExceptionInInitializerError; event loop continuing ...
    java.lang.ExceptionInInitializerError: java.lang.NullPointerException
    at de.audi.tghu.storage.DSIStorageProvider.getInt(Unk nown Source)
    at de.audi.tghu.storage.StorageManagerImpl.getInt(Unk nown Source)
    at de.audi.tghu.fwhmi.KbdHandlerDSI.<clinit>(Unknown Source)
    at java.lang.J9VMInternals.initializeImpl(Native Method)
    at java.lang.J9VMInternals.initialize(Unknown Source)
    at de.audi.tghu.fwhmi.FwHMI.startLastMode(Unknown Source)
    at de.audi.tghu.fwhmi.FwHMI.getInstance(Unknown Source)
    at de.audi.atip.base.Framework.getHMIService(Unknown Source)
    at de.audi.tghu.fwhmi.EventTrail.logEventDispatch(Unk nown Source)
    at de.audi.tghu.fwhmi.EventQueue.dispatchEvent(Unknow n Source)
    at de.audi.tghu.fwhmi.EventQueue.eventLoop(Unknown Source)
    at de.audi.tghu.fwhmi.EventQueue$EventDispatchThread. run(Unknown Source)
    /lsd/lsd.sh[35]: route: not found
    Unrecoverable HMI Error, trigger a system reset!
    Reason: Incomplete HMI startup! System will shut down!
    Regards
  4. Re: bricked mmi 3g unit
    Oct 2012
    Estonia
    47 Post(s)
    So, you have no idea what is wrong with your unit, but as last"try" you changed hdd, where you took img for cloning, from your old hdd which may be not operative anymore or tested image from web?
    A48K5 2008 Retrofits: FL Taillights, Bixenon, Color Cluster & FL S5 Cluster, ADS with button, MMI 3G & 3G+
    Other: Ecu tune, Front bumper valance "Rieger look", Sideskirts, VCDS mod, Interior leds, B/O tweeters+activsub, Soundproofing,Tinted windows, Interior 6D carbon wrap, Painted calipers, 18" Wsp wheels Peeler style, FL gearknob, Chrome door handles, Efficiency prog via cluster & gateway flash...
  5. Re: bricked mmi 3g unit
    May 2014
    Darlington
    45 Post(s)
    You have done everything I would have do to recover the unit, a full restore of the software from the command line should work, so to me your looking at a system board issue. Only other thing I can think of is to try and load the original MMI software on the unit, or near enough the original version. Then if that works upgrade to the current version.
  6. Re: bricked mmi 3g unit
    Feb 2015
    Sweden
    Thanks for answer,
    I read in another forum that the mmi unit would boot up whitout an harddrive, but you wouldnt be able to use the navigation.
    So tog out the old harddrive and prepare a new one and only created the partitions. No copy at all.
    It fels like I have read everything on the internet and tried everything.
    How could I tell the original firmware? Havnt tried that one yet.
    Regards
  7. Re: bricked mmi 3g unit
    May 2014
    Darlington
    45 Post(s)
    What manufacturing date is on the unit?
  8. Re: bricked mmi 3g unit
    Feb 2015
    Sweden
    Its made in 2008
    Regards
  9. Re: bricked mmi 3g unit
    May 2014
    Darlington
    45 Post(s)
    I would be looking to try version HNav_EU_K0022_1_D1.
  10. Re: bricked mmi 3g unit
    Feb 2015
    Sweden
    Damn, that's old �� I will have to search the net for that one.
    If not somebody have it their storage somewhere and can help me out?
  1. Question Q7 VEYRON MMI 2 unit
    By Quattros in forum In Car Entertainment
    Last Post: 31-07-2016, 02:31 PM
  2. mmi 3g head unit
    By mogsy in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-04-2016, 09:24 AM
  3. MMI head unit...
    By matrixpt in forum VCDS - General Questions
    Last Post: 01-06-2014, 12:14 AM
  4. Where is the MMI unit situated?
    By drrgriffiths in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 19-10-2010, 01:55 PM
