Thread: Fitting LED DLR's
  1. Fitting LED DLR's
    Dec 2016
    New Forest
    I've seen a lot of LED DLR/Indicator strips on eBay and around the net which are designed to replace the sidelights and indicators to make the front end of the car look more modern. It looks to me like you have to have the headlight switch set to the side light position to turn these on. Is there a VCDS setting which will turn the sidelights on all the time so when the headlight switch is in the auto position they come on? It seems a bit pointless installing DLR's that you have to turn on manually. Or have I miss understood all the DLR strips on ebay?
    Car is a 2006 Q7 S-line.
  2. Re: Fitting LED DLR's
    Feb 2014
    Cork, Ireland
    Can't help you with the VCDS functionality but those ebay drl/indicator units are pretty rubbish. They are of poor quality (water ingress likely) and not very bright either in daylight.
    Proper factory quality DRL's are big money as you need MY2010+ xenon headlights and led indicators & coding etc. See Kufatec etc. for prices.
  3. Re: Fitting LED DLR's
    Dec 2016
    New Forest
    Thanks for this.
  1. Please Help LED DLR fail
    By cm.popa in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-09-2016, 10:09 AM
  2. Errors after fitting LED bulbs
    By longmanjon in forum Audi A6 - C7 Forum - 2011-
    Last Post: 01-09-2016, 09:01 PM
  3. Question Left Main Beam warning after replacing DLR bulbs with LED?
    By ntp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-05-2012, 07:05 PM
  4. LED DRL fitting?
    By dwl99 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-05-2010, 01:53 AM
  5. DLR LED Project on A4 B6
    By sbuk73 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-02-2008, 11:10 PM
