Thread: Temperature sensors
  1. Temperature sensors
    Nov 2016
    Brisbane Australia
    Can anyone tell me where are all the temp. sensors located in the TFSI engine/ Audis3 8p 2007. Is there something on the web that i havent found. I replaced the coolant temp. sensor next to the battery. Is there any others?
    Thanks Richard
  2. Re: Temperature sensors
    Jul 2007
    glasgow
    26 Post(s)
    whats the fault ?
    You may have a fuel temp sender, its the same as the coolant one; fluid is fluid
    Usually all cars have 2 coolant sensors. One at the thermostat for dashboard/ ecu and the other at or near the radiator for the cooling fan to come on
  3. Re: Temperature sensors
    Nov 2016
    Brisbane Australia
    Quote Originally Posted by niall campbell View Post
    whats the fault ?
    Both fans are coming on and at full speed for a about 5 minutes after engine is turned off.
    If engine doesnt reach running temps. they wont come on, but any other time they come on no matter how hot or cool the day is.
    Ive replaced the coolant temp. sensor next to the battery.
  4. Re: Temperature sensors
    Jul 2007
    glasgow
    26 Post(s)
    the fans have a capacitor on them that are prone to go
    I don't know if vcds can read the temp of the fans or not ?
  5. Re: Temperature sensors
    Nov 2016
    Brisbane Australia
    Is this the module in the center of the main fan?
  1. Coolant Temperature Sensors.
    By Meic in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-06-2016, 05:49 PM
  2. 1 one 2 coolant temperature sensors? Loud fan!
    By monz87 in forum Golf MK5 - 2004 - 2009
    Last Post: 23-05-2016, 02:17 PM
  3. Question 2 engine coolant temperature sensors A4 B6 2.0
    By Glastulla in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-03-2013, 12:11 AM
  4. High Temperature Warning when the temperature is fine
    By Hairsy in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-01-2012, 05:46 PM
  5. Temperature gauge reading lower than actual temperature
    By garymansell in forum Golf MK3 - 1993 - 1999
    Last Post: 24-08-2009, 04:29 PM
