Thread: Q7 4M Homelink RetroFit
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
  1. Re: Q7 4M Homelink RetroFit
    #31
    Jun 2017
    Timisoara, Romania
    Hello Andy,
    please help me also 'cause I'm lost :-)
    I did the same retrofit on my VW Touareg 7P My2014 with the following components (purchased from ebay):
    - buttons: 7P6 959 719
    - new trim
    - control unit: 4G0907410A and 4H0907410
    - original support for control unit in front bumper beside VW emblem
    - I build the harness and connectors and attached the 2 LIN lines in the corresponding control units J519 and J393 according to the wiring diagrams
    I have enabled in green menu the Garage door opener and also in VCDS I selected teh coding bits in both units (what I saw in the long coding as corresponding to garage door opener).
    I have now the following status:
    - the buttons are recognized in 09 module as subcomponent
    - I cannot see the control unit as being recognized as subcomponents in any of the modules
    - Pressing the Garage Door Opener menu I have the error "Function is not available"
    - if I press the buttons with the first control unit mounted I have no RF telegram coming from the module
    - pressing the buttons with the second module I bought: 4H0907410 I have RF telegrams transmitted by the module for each of the 3 buttons -> I have and RF monitor box that I used
    - the control unit however is doing something and communicates with the buttons obviously, moreover if I disconnect the control unit, the buttons/LED on them behaves differently -> not lighting up at all (with the control unit the green LED flashes rapidly for each button press.
    What am I doing wrong?
    Thanks for help
  2. Re: Q7 4M Homelink RetroFit
    #32
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    New here so please be patient with me.
    I am attempting to install the homelink in my 2016 Audi q7 4M.
    I have sourced all the hardware and installed.
    Using VCDS I have enabled " garage door opener " in the central convenience module Byte 22 /Bit 0
    I can now see the garage door operating module and the garage door control module listed a sub modules in 09 central electrics
    So I assume the hardware part is sorted ok. ( lights flash when I press buttons! )
    As yet I am unable to find any reference in the MMI screen to Garage Door Opener, so am unable to do any programming.
    I have searched through the coding options of various modules without any success.
    I am at a bit of a loss now as to how to proceed.
    Any help would be most appriciated.
    Keith
  3. Re: Q7 4M Homelink RetroFit
    #33
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by mazerati View Post
    Hi Andy,
    Keith
    Keith
    Drop me a PM
    Andy
    Q7 272PS | ABT Tuned to 325PS / 680Nm | Tech Pack | Dyn Pack | Matrix | Pan Roof | Trailer | Drv+Pass Mem Seats | TV | NightV | BOSE | DVD Chger | Homelink | Soft Doors | Heat+Snd Ins Glass | Priv Glass | Heat W/Screen | Heat Steer Wheel | Adv Key | Elec Boot Cover | Elec Steer Column | Side Assist | Air Susp | Ambient Light | Heat+Fold Mirrors | Park Assist Pack | Adv TPMS | Load Fix Kit | Black Turbine Alloys | Matte Black Wrap | ABT Door Leds
  4. Re: Q7 4M Homelink RetroFit
    #34
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    Thanks for taking the trouble to respond.
    Unfortunatly being new to the forum I am not yet allowed to send PM's.
    Not sure if you can send me one or if I can reply to it?
    Regards
    Keith
  5. Re: Q7 4M Homelink RetroFit
    #35
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    I have been digging into some unchartered teratory today.
    Playing with some Adaptions that I've not dared fiddle with before.
    Anyhow, I have managed to get the "GARAGE DOOR OPENER" listed on my MMI screen, under CAR / Vehicle Settings.
    So another small step forward.
    What I am up against now is that this option is grayed out compared to the other options
    and when select it I gat the message " this function is unavalable at this time "
    I have been searching for other bytes and bits to play with without success.
    So am stuck once again.
    A point in the right direction would be most wellcome.
    Regards
    Keith
  6. Re: Q7 4M Homelink RetroFit
    #36
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    I'm sure I have seen you on the Ross-Tech Forum.
    I have left you a PM there.
    Regards
    Keith
  7. Re: Q7 4M Homelink RetroFit
    #37
    Mar 2010
    37 Post(s)
    228 Post(s)
    Keith.
    I'll ping you what you need to do. I'll check the RT forum and respond.
    Your nearly there.
    . Andy.
  8. Re: Q7 4M Homelink RetroFit
    #38
    Feb 2019
    MIDDLESBROUGH UK
    26 Post(s)
    Hi Andy,
    Many thanks for all your help with this, my homelink is fully opperational now.
    What a star!!
    Keith
  9. Re: Q7 4M Homelink RetroFit
    #39
    Jun 2013
    Andy, any chance you could PM me pls so I can send you a message? Thanks, Dan
  10. Re: Q7 4M Homelink RetroFit
    #40
    Mar 2010
    37 Post(s)
    228 Post(s)
    Quote Originally Posted by danbrier View Post
    Dan. Pinged you a pm.
    Andy
  1. RetroFit HomeLink
    By andyhud007 in forum Q7 - 4M Forum - 2016 -
    Last Post: 05-09-2016, 04:22 PM
  2. Retrofit Homelink to FL A6
    By A4Bev in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-10-2015, 10:10 PM
  3. Retrofit of Homelink in new Audis
    By troc in forum In Car Entertainment
    Last Post: 19-10-2010, 04:44 PM
  4. Question Homelink visor ?
    By richiemac in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 07-04-2010, 07:22 AM
  5. HOMELINK Optional extra
    By Simwaz in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-02-2008, 12:02 AM
