Thread: Possible electrical gremlin???
Results 11 to 20 of 23
  1. Re: Possible electrical gremlin???
    #11
    Jan 2017
    Sutton
    Hi Niall,
    The welcome home lights are switched off in the mmi or does it change depending on what key you use as it came with 2. one is well worn and the other barely used so im using the latter
    I didnt lose any settings in the mmi apart from the time and the trip reset.
    The needles lighting up was happening before I changed the battery
  2. Re: Possible electrical gremlin???
    #12
    Jan 2017
    Sutton
    Gupsterg,
    I have a Bluetooth obd2 scanner and an app called torque pro. I used it on my cupra loads and it also worked on a mates 08 tts so is it worth giving this a try. I understand the port is above the accelerator and is pink. Is that right?
  3. Re: Possible electrical gremlin???
    #13
    Sep 2011
    Lurking over a keyboard ...
    Give it a try , some tools don't catch all DTCs/data (VCDS DTC compare), yes that's the port .
  4. Re: Possible electrical gremlin???
    #14
    Jan 2017
    Sutton
    Cool. Thanks ☺
    0 2 0
  5. Re: Possible electrical gremlin???
    #15
    glasgow
    yes EACH key is stored in the car for different settings
    Your wifes key might have the lights on in the MMi , where yours is switched off
    Some cars with electric seats go further, and they adjust the seat to different keys
  6. Re: Possible electrical gremlin???
    #16
    Jan 2017
    Sutton
    Its looking like water getting in somewhere. I didnt see it do yesterday or the day before but I've just got back from work and they are lit up and its chucking it down here so will have to have a good look around the car at the weekend
  7. Re: Possible electrical gremlin???
    #17
    glasgow
    water in the footwell ?
    If so, you need to take wipers off, remove plastic cover over the wiper motors and clean the scuttle/ plenum chamber out
    then find the drain holes by prodding around with a large screwdriver under the brake servo
    I just take the rubber drain holes out as they just choke up
    then hose the area out to get rid of all the leaves and grime
  8. Re: Possible electrical gremlin???
    #18
    Jan 2017
    Sutton
    Interior is bone dry no damp smells or anything like that and the windows hardly ever fog up. I had a seat leon with a dodgy door seal and the windscreen was constantly fogging up.
    I will still look at the plenum chamber and any other drainage channels I can find plus electrical cubby holes
  9. Re: Possible electrical gremlin???
    #19
    glasgow
    so where did you see the water ?
  10. Re: Possible electrical gremlin???
    #20
    Jan 2017
    Sutton
    I haven't seen any. I'm guessing as I didnt see the fault in the last 2 days when it has been dry yet when I got home today the needles were flickering away. Its been raining here since 10 this morning so its either water related or a fluke I guess
  1. Electric window gremlin
    By scotty33 in forum Ibiza - Cordoba
    Last Post: 01-08-2016, 03:56 PM
  2. Question Electric gremlin 1.8T avant
    By paulw in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-10-2015, 05:59 PM
  3. Headlight Gremlin
    By taxi3528 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 26-01-2015, 07:03 PM
  4. B3 90 2.3E Electrical Gremlin???
    By dgacampbell in forum 80 - 90
    Last Post: 26-01-2012, 07:48 PM
  5. Gremlin in engine management
    By Jim1289 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 05-08-2011, 10:36 PM
