Thread: A5 2013 FL vcds fault humidity sensor (g260)
  1. A5 2013 FL vcds fault humidity sensor (g260)
    Dec 2008
    12 Post(s)
    I read these two faults in module
    08 -Auto HVAC (J255)
    1 Fault Found:
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory
    and
    09- Cent. Elect. (J519)
    1 Fault Found:
    01229 - A/C Humidity Sensor (G260)
    014 - Defective
    Purchased new Humidity sensor
    4G0 907 658 A which is mounted under the hood on passenger side (LHD) but fault didnt dissapeard.
    I have inner back mirror with rain/light sensor on windshield. The windshield has been changed because it was damaged. I take a look at the rain sensor under mirror trim and found out that flat cable is damaged on the bottom. Is there a humidity sensor g260? VCDS is giving me error on humidity sensor 014- Defective but rain/light sensor works well. I'm not sure is it a must to change whole sensor because of defective humidity sensor or to leave it as it is?
  2. Re: A5 2013 FL vcds fault humidity sensor (g260)
    Jan 2018
    Qala, Malta
    i have the exact same faults. following !
  3. Re: A5 2013 FL vcds fault humidity sensor (g260)
    Dec 2008
    12 Post(s)
    Quote Originally Posted by BONDIS View Post
    Check the rain/light sensor 8U0 955 559B under windshield, mine was faulty (someone broke flat cable when changing windshield) and I replaced it with new from AliExpress LINK​​​​​​​
  1. Please Help Air con, Horn, humidity sensor, auto-dim doesn't work
    By soupknife in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-11-2015, 03:25 PM
  2. Question Someone with a VCDS for 2013 Audi A4
    By Audia42013 in forum VCDS - Help Requests
    Last Post: 23-06-2015, 10:17 PM
  3. Vcds and 2013 Transporter T5 problem
    By mark_w in forum VCDS - General Questions
    Last Post: 27-10-2013, 12:56 PM
  4. Replies: 0
    Last Post: 03-06-2013, 08:04 PM
