Thread: Q7 acc not available!! Brake guard off after fitting westfalia towbar
  1. Q7 acc not available!! Brake guard off after fitting westfalia towbar
    Jan 2017
    Cardiff
    Hi, I have just fitted a westfallia towbar and dedicated electrics I bought from pfjones to my 2008 Q7. Plugged in light board and all working fine.. as I was driving the car to local towbar specialist to get it programmed I noticed the brake guard and acc not available!! Notices. Got the car programmed using westfallia hand held computer all ok but still brake guard and acc problem on car ..
    is this common or have I done something wrong or disturbed something when fitting?
    Any help would be appreciated, thanks.
  2. Re: Q7 acc not available!! Brake guard off after fitting westfalia towbar
    Mar 2009
    Manchester, England
    Hi, you shouldn't be getting any error messages after it has been coded. Nothing could have been disturbed really, the messages would be there because the BCM plugs have been unplugged. If you take it back to where it was coded and have them clear the faults first. All should be well but just check with a trailer board again.
    If you still have trouble, call us with your order details and ask for technical help 0161 886 5796
    PF Jones Towbars | National Mobile Towbar Fitting | Audi Towbars
    We will beat any like for like price on all Witter and Westfalia Towbars 0161 872 4755
  3. Re: Q7 acc not available!! Brake guard off after fitting westfalia towbar
    Jan 2017
    Cardiff
    Ok, job done.. checked all connections, fault codes deleted and code number had to be changed on ACC I think.
  1. fitting westfalia towbar to passat estate
    By creedxup in forum Passat - B5 Forum - 1997 -2005
    Last Post: 11-06-2018, 09:40 PM
  2. Q7 westfalia towbar acc and brake assist problem
    By Waverunner52 in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 19-01-2017, 12:39 AM
  3. Question ACC with Brake Guard...?
    By AGW82 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-04-2013, 07:46 AM
  4. Question Westfalia towbar fitting
    By bambamjj in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2011, 03:15 PM
  5. fitting Westfalia towbar to passat
    By creedxup in forum Towbars, Towing, Roof Boxes & Bike Racks
    Last Post: 23-03-2010, 04:50 PM
