Thread: CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
  1. CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    Jan 2017
    Wem, UK
    Had intermittent starting problems i.e. would start then die after 1 to 3 seconds. Then suddenly would right itself and start and would be fine. This could be after 1 crank, or 20. Many days, even cold ones it would start ok 1st time. I looked at an eobd reader, and nothing strange there. Took for VCDS scan and no codes either. Last time it wouldn't start I removed the 'silver' pipe that feeds into the inlet from the EGR (right at the front) and blocked the port into the inlet with a cork. It started straight away, with smoke etc. belching out of the disconnected egr pipe. I repeated this, pipe back on - no start, pipe off and inlet blocked - start. Can anyone confirm that the EGR shoud definately be closed at idle. After a couple of minutes of idling the smoke had gone, but still gases puffing out of the EGR pipe. Car has since gone back to the garage, a VAG specialist, and I told them my findings. They said they would confirm diagnosis and replace EGR, but now seem reluctant to do so in the absence of codes! Would LOVE to hear from anybody who's familiar with these, particularily to confirm my premise that nothing should get through the EGR at idle, and particularly while starting. Many thanks!!
  2. Re: CAYC 1.6 tdi diesel engine. Unresolved EGR problem.
    Oct 2017
    leeds west yorkshire
    hi nickbell1uk did you solve the problem i have the same problem thanks
  1. Question Advice/tips on cleaning EGR & Turbo on my 2001 SharanDI AHU Diesel Engine
    By heave in forum Touran - Sharan - Caravelle
    Last Post: 03-02-2016, 07:00 PM
  2. Golf 1.6 Bluemotion CAYC Engine EGR Replacement guide
    By dave254 in forum Golf MK6 - 2009 - 2013
    Last Post: 23-11-2015, 05:06 PM
  3. Please Help VW Polo Tdi 1.4 Diesel 2000 ..... Seized engine problem!!
    By Eymoutiers in forum Polo - Derby - Lupo - Fox
    Last Post: 16-04-2015, 06:17 AM
  4. Audi A3 - 8P - 2010 - 1.6 TDI (CR) - CAYC - Timing Marks
    By DCEd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 15-04-2015, 10:12 PM
  5. 2003 tdi Diesel 1.9 Passat Estate Sport EGR valve problems
    By passattt in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-07-2012, 01:11 PM
