Thread: Le Mans 3.0TDI - niggles?
  1. Le Mans 3.0TDI - niggles?
    Apr 2015
    United Kingdom
    I have couple niggles on my A6 and in particular related to a couple of items that stopped working in a space of last three weeks,
    - horn is no longer working and
    - the Xenon headlight washers are off
    Checked the fuses (all okay) and there are no 'errors' on VCDSs... before i take the bumper off for closer inspection i was wondering if you have any hints or other areas i could look into?
    Many thanks.
  2. Re: Le Mans 3.0TDI - niggles?
    Aberdeen
    63 Post(s)
    Washers could just be a fluid hose loose or broken fitting. Pretty sure they pop up with water pressure so when there is no water, the washers don't come up.
  3. Re: Le Mans 3.0TDI - niggles?
    Apr 2015
    United Kingdom
    I checked it couple of times with washer fluid fully topped up and lights ON but still nothing.
    I can hear a pump-type sound related to the headlight washers but they don't 'move' so to speak.
    How easy/difficult is it to take the bumper off?
    And, do you have suggestions which hoses are required (eg. Diameter)?
    Ta
  4. Re: Le Mans 3.0TDI - niggles?
    Aberdeen
    63 Post(s)
    I think you can check the hose connections from the passenger wheel well. Remove wheel then the liner to gain access. Hopefully someone can confirm this first.
    One of the guys on here (Gupsterg) is great with the C6. Try a PM to him or look for some of his posts.
  1. A6 3.0TDI Quattro S line Le Mans
    By niedzial1983 in forum New Member Introductions
    Last Post: 31-05-2016, 04:55 PM
  2. A6 3.0Tdi Le Mans Special Edition Value
    By anth8910 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-10-2014, 03:25 PM
  3. New member looking for a 3.0tdi Le Mans.
    By Happybiker in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 15-08-2013, 08:13 AM
  4. Please Help 57 plate Audi A6 3.0tdi Le Mans
    By Webby4736 in forum In Car Entertainment
    Last Post: 27-02-2013, 07:46 AM
  5. A6 3.0TDI Le Mans - 07 - Suspension knocking...?
    By markorbilly in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 29-04-2012, 09:30 AM
