Thread: Upgraded washer jets
Page 1 of 9 123 ... LastLast
Results 1 to 10 of 81
  1. Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    Found on the A6 part of the forum that newer cars are coming with washer jets that spray a mist rather than the normal 3 jets.
    I bought a set last week and they are much better. They cover the whole window in a fine mist and seem to clean better as the fluid covers the whole window.
    Part numbers are 4G0955987A & 4G0955988A. They are a direct swap and easy to adjust with a torq bit screw driver.
    2 4 0
  2. Re: Upgraded washer jets
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks M1tchy, I hate the existing 3 jet washers and can never get them to cover the whole screen. Where did you buy yours and what did they cost. I am seeing a huge price variation.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    Me too. Really missed them when I had them on my insignia.
    I got them new from Audi. They were £7 something each plus VAT. Got both for less than £20 and about 60 secs to fit.
  4. Re: Upgraded washer jets
    Feb 2014
    norway
    Is that the heated ones?, need that here in Norway.
    Do you happens to have the part #?
  5. Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    Yes these are the heated ones mate.
    I bought another set yesterday for the wife's A5 (exactly the same fitting) so will take a few pics - it's probably not needed though.
  6. Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    Fitted them to my wife's A5 this morning. Same part number and exactly the same fitting.
    This is the view from the front of the jet. The screw on the right adjusts the height of the spray.
    They are also marked L + R so you know which side they go on.
    To remove the old ones, open the bonnet, the pull the old nozzles from the front in a pendulum motion. They only move as far as in the pic. Then remove it.
    Next remove the connection for the fluid. Slide the plastic retainer back about half a cm making sure it doesn't ping off and the pipe then comes off.
    Next is the electrical connection for the nozzle heater. Slightly lift the clip and pull the plug so it comes off.
    Install in reverse order and test. The height of the jets can be adjusted with the bonnet closed.
    And this is them working. I've also added a system called heatshot which heats the washer fluid hence the steam after a few seconds.
    https://youtu.be/_dJ0WEbBYWc
    4 2 0
  7. Re: Upgraded washer jets
    Feb 2016
    Blaydon, North east England
    53 Post(s)
    Do you think these will fit on a C7 A6?
    2015 A6 Allroad 3.0TDi 218 CRTE - NEW
    2012 A6 Avant 3.0TDi Multitronic - OLD
  8. Re: Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    I can't see why not mate. It's an A6 part number that I've posted and they fit the A7 (63 plate) and A5 (12 plate)
  9. Re: Upgraded washer jets
    Feb 2016
    53 Post(s)
    champion, its about the only thing I miss from my previous car, a Peugeot 407. I found you use a lot less water with the fan rather than jets
  10. Re: Upgraded washer jets
    Feb 2013
    Gloucester
    57 Post(s)
    Yeah me too, although now mine produce steam which looks cool I'll probably use more
  1. Replies: 4
    Last Post: 16-11-2015, 03:42 PM
  2. Washer Jets...
    By danclyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-01-2014, 12:46 PM
  3. Question Washer Jets
    By Rusk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-02-2011, 06:51 PM
  4. Washer jets
    By bakili in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 24-12-2010, 05:19 PM
  5. changing the washer jets to wide spray jets
    By audisingh in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2010, 08:54 AM
