Thread: Complete electronics failure??
Results 1 to 10 of 11
  1. Complete electronics failure??
    Tewkesbury, UK
    Hello folks
    Been having problems lately with a mysterious drain on car battery (a brand new Bosch battery).
    Had battery and alternator tested and both absolutely fine. Nothing being left on and whenever I check the battery sporadically with an amp-clamp there is no recorded current draw.
    Went out today and again, completely flat, having started fine yesterday.
    Can't even jump car as now dash lights flicking/clicking on/off. Is this ecu or the immobiliser kicking in? Problem is I can't seem to unset anti-theft system...
    All doors currently unlocked and I can only lock the front two using the emergency key.
    Going spare with this one as I currently have best part of 2 tonnes of scrap metal on drive. PLEASE HELP!!
    Car is a 2006 Passat estate 2.0tdi (140)
    Thanks in advance.
    '56 B6 Passat Estate 2.0 TDi 140 SE with leather upholstery & sports pack
  2. Re: Complete electronics failure??
    Sep 2008
    SE London
    Have you changed your radio at all?
    Is there any spark when you disconnect the negative battery terminal clamp? While you're there, remove it and
    connect a charger -- a trickle overnight one will do. I'm skeptical about these "amp clamps" and the other testers Halfords put
    on to pronounce your battery "bad" or otherwise.
    What is the battery terminal volts with everything off (but negative connected)
    And with negative disconnected?
    And with starter motor trying?
    What colour are your headlights when switched on? And after a minute?
    Try connecting the battery negative terminal by black jump cable to the engine block itself. Often the electrical bond goes bad which shows up especially in high current conditions when operating starter motor
    Let us know how you get on?
  3. Re: Complete electronics failure??
    Tewkesbury, UK
    Quote Originally Posted by RichardSEL View Post
    Yes, changed radio a few months ago and it does tie-in timing wise. I noticed inside the car the sound of a relay clicking once every 10 seconds or so. Sounded like it was coming from behind centre blower vents...
    Just picked up a battery charger so will get that going and let you know how I get on.
    Any ideas on the clicking and flashing dashlights? I'm thinking immobiliser, but not sure. Also, how do I disengage it if neither key is doing anything? Should i be able to reset with a fully recharged battery?
  4. Re: Complete electronics failure??
    Apr 2016
    Ashburton
    The erratic lights and clicking is due to the lack of power to wake the BSI / body control module up this is why everything goes erratic.
    When you fitted your radio did you install a wiring harness adaptor as if you didn't you will cause short circuits to the BSI as the genuine radio uses a active aerial amplifier feed and adaptive speed volume control these need to be disabled when fitting after market units or the BSI won't go into hibernation/ sleep mode when car is locked.
  5. Re: Complete electronics failure??
    Tewkesbury, UK
    Quote Originally Posted by turboextreme View Post
    Ah, that would seem to make a lot of sense. Any idea on what harness adapter I need?
    Many thanks
  6. Re: Complete electronics failure??
    Sep 2008
    SE London
    Quote Originally Posted by pcplum View Post
    Many thanks
    Depends on what head unit you bought? There's a range of Quadlock adapters and CANbus/steering wheel adapters at Connects2 site
    If you upgraded an OEM headunit, or to some of the more recent Android headunits, then you'll need an updated CANbus module too.
    A '56MY B6 would have a "C" version. To change out you'll need someone with VCDS to do the fresh module's coding
  7. Complete electronics failure??
    Tewkesbury, UK
    It's an Android head unit. It came with a quadlock connector, and canbus stuff all seems to be working (doors open, odometer, temp, battery voltage info, reversing lines that move with steering wheel etc). I don't have steering wheel controls.
    This is the head unit:
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...=1378954044013
    So, given the above, do you recommend a replacement canbus module, and any idea on costs, fitted?
    You'll have to forgive my utter ignorance with all this - auto electronics are definitely NOT my forte!!
    Please keep the help coming! Happy new year.
  8. Re: Complete electronics failure??
    Tewkesbury, UK
    Looking at some other threads/forums, it seems other folk have had a battery drain issue when changing stereo units and an updated canbus module gateway is the answer. So, the golden question is, if I upgrade to the 'Q' module, will my issues be solved? A quick scan of posts suggests dealer would charge £250-300 to replace and reprogram new module?? Also seen plenty of warnings to stay away from the Chinese-made ones on eBay...?
  9. Re: Complete electronics failure??
    Sep 2008
    SE London
    The latest Android headunits don't completely switch off (like the up-to-date OEM headunits RNS510 etc)
    The "Q" version is the latest but you don't need to go that far for an OEM one. Version "F" or later should
    be alright
    Re-coding should be done by VCDS. As you're buying second hand it might still have latent coding in it from
    the doner car. So your original coding from your "C" version will have to be noted down, then coded into
    your "F" version or greater when it's changed out.
    I did a FAQ in this forum many years back. But anyways, the module's behind your heater control panel, mounted
    upside down held in place by a bar with two bolts either side.
    Disconnect battery and loosen the bolts and your old module will slip out sufficiently for you to lift the plug's latch and unplug. Reverse procedure with replacement. Replace your heater control panel (if you only have the four position knob Climatic system be careful the Bowden cable doesn't slip out -- it will have to go back in the same position as removed)
    If you have two window Climatronic then it's just that panel out and remove the three plugs at the back and then reach in.
    Re-connect battery and then do the coding. Tewksbury's a tad too far for me, so you might need someone local to do the coding:
    Here's the URL:
    https://www.google.com/maps/d/viewer...5cfcb6158e0447
    Or it's a VW indie. They shouldn't mind fitting a "F" or later second hand part.
    Search for 3C0 907 530 <suffix letter>
    Hope that helps. Keep us updated?
  10. Re: Complete electronics failure??
    Tewkesbury, UK
    Many thanks for this - it's very much appreciated. I will get on the hunt for a replacement module.
    Will keep you updated.
    Thanks again.
  1. B7 electronics on B6
    By Jim2013 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-10-2013, 06:06 PM
  2. Important ESP malfunction, complete break failure!
    By swjoduk in forum Touran - Sharan - Caravelle
    Last Post: 14-02-2013, 10:16 AM
  3. Voodoo electronics
    By roboman in forum Golf MK3 - 1993 - 1999
    Last Post: 05-10-2010, 05:06 PM
  4. complete failure!
    By Quill in forum Golf MK3 - 1993 - 1999
    Last Post: 01-01-2010, 02:30 AM
  5. Question Complete Radio/CD failure
    By GilesC in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 08-08-2009, 10:13 PM
