Thread: 2016 Q5 MMI Navigation Plus hidden menu
  1. 2016 Q5 MMI Navigation Plus hidden menu
    Dec 2016
    Worthing, England
    Hi there everyone !
    I'm new to this group so I thought I'd ask a fairly simple question, if I may please ?
    I've just bought a '66 plate Q5 with the 'MMI Navigation system Plus' and I've seen from the 'net that there's a hidden menu that can be used to alter certain things but I can't seem to get into it (or appear to need a VAGCOM cable to do so).
    Am I correct in my thinking, in which case I'll give up trying as I'm not bothered enough to spend lots of cash on the cable/software, or am I just being a bit daft and haven't used the correct set of button presses ?
    The button on my Q5 are (from top left) -
    NAV 'soft key' rotary dial 'soft key' RADIO
    TEL 'soft key' rotary dial 'soft key' MEDIA
    MENU BACK CAR
    Hopefully that all makes sense but if you need to me answer any questions about it, please just ask
    cheers
    Mike
  2. Re: 2016 Q5 MMI Navigation Plus hidden menu
    Nov 2009
    46 Post(s)
    Hidden menu is limited, don't be messing with settings you don't have knowledge of ad you can brick your 5F unit and is not covered under warranty.
  3. Re: 2016 Q5 MMI Navigation Plus hidden menu
    Dec 2016
    Worthing, England
    thanks for the quick reply Chris, it was more out of curiosity to see what was in there, rather than actually changing any settings as I have read that it can be quite dangerous to just randomly alter stuff, and it doesn't look like there would be much I'd want to do, but I like to understand all the 'features' available, even if I don't actually use them.
  4. Re: 2016 Q5 MMI Navigation Plus hidden menu
    Dec 2016
    GB
    Might be worth thinking about and Obdeleven, Mike. Not nearly as much money as a proper VCDS cable but can do a fair bit. I enabled needle sweep on mine quite easily, I am a novice too. Only problem I have with it is I put it "away" somewhere and can't find it now. Oops
    Sent from my Nexus 10 using Tapatalk
  1. Doh - MMI Hidden menu, messed about with it
    By bells0 in forum In Car Entertainment
    Last Post: 05-12-2013, 11:00 PM
  2. MMI 2g hidden menu
    By Tim B in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 16-04-2013, 01:12 PM
  3. Accessing MMI Hidden Menu on Facelift B8 with MMI 3G
    By aled_31 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-04-2012, 08:34 PM
  4. MMI Hidden Menu
    By dragondownsouth in forum A8 - S8 - V8
    Last Post: 22-12-2011, 05:22 PM
  5. Accessing hidden menu on 2g MMI
    By MarkBS in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-03-2010, 03:34 PM
