Thread: Golf GT TDI 2.0 Crank, no start issue
Results 1 to 10 of 14
  1. Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    bridgend, south wales
    Hi guys,
    Hoping someone can help with this head scratcher! Golf has suddenly decided it doesn't want to start. I drove to the shops the other day and on return to the car, it was just cranking but not starting. After 3 or 4 mins I managed to get it started and got home without issue but it wouldn't start after parking up. In the evening, I managed to get it started first time and drove away, only for the car to judder and splutter to a halt 100yds down the road. Again, it cranked but would not start. After another 5 mins trying, i managed to get it started (with the throttle fully pressed down) and whizzed back home.
    Since then, I've barely been able to get it started. It now only cranks, and on the rare occasions it does fire up, it cuts out after 2 or 3 seconds.
    I've done a full scan with VCDS and did have a fault for engine speed sensor (G28). I cleared this fault and it hasn't flagged back up so i'm wondering if that was potentially a symptom of something else? I've got the part on order but any other suggestions in the meantime would be much appreciated! The tachometer was initially moving when trying to start but barely moves now.
    Other points:
    • The fuel pump is priming and fuel is reaching the filter at least
    • I've tried both keys (in-case immobiliser issue)
    • Inspected Cam belt and don't see any damage/missing teeth
    • Battery 6 months old and fully charged
    VCDS log below - ABS and steering angle faults due to me unplugging battery so not concerned about them
    Thursday,29,December,2016,20:20:22:12017
    VCDS Version: 16.8.4.2 (x64)
    Data version: 20161129 DS267.0
    Mileage: 222340km-138155miles
    01-Engine -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    44-Steering Assist -- Status: Malfunction 0010
    56-Radio -- Status: OK 0000
    7D-Aux. Heat -- Status: Malfunction 0010
    Address 01: Engine Labels: 03G-906-016-BKD.lbl
    Part No SW: 03G 906 016 KC HW:
    Component: R4 2,0L EDC G000SG 9971
    Revision: 12345678 Serial number: VWZ7Z0D0054531
    Coding: 0000072
    Shop #: WSC 00478 210 91483
    VCID: 6EFD374479B9F4322B-803A
    1 Fault Found:
    16705 - Engine Speed Sensor (G28)
    P0321 - 000 - Implausible Signal
    Freeze Frame:
    RPM: 0 /min
    Torque: 258.0 Nm
    Speed: 0.0 km/h
    Load: 0.0 %
    Voltage: 11.32 V
    Bin. Bits: 00101000
    Idle Stabilization: 0.0∞KW
    RPM: 42 /min
    Readiness: 0 0 1 1 1
    Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
    Part No: 1K0 907 379 K
    Component: ESP FRONT MK60 0103
    Coding: 0023170
    Shop #: WSC 00046 000 540672
    VCID: 3A55CB1475716892C7-806E
    1 Fault Found:
    01314 - Engine Control Module
    013 - Check DTC Memory - Intermittent
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No: 1K0 907 044 AB
    Component: ClimatronicPQ35 066 0404
    Shop #: WSC 00000 000 00000
    VCID: 67F342605643257A68-8032
    No fault code found.
    Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
    Part No SW: 1K0 937 049 T HW: 1K0 937 049 T*
    Component: Bordnetz-SG 1.0 H30 0704
    Revision: 00030000 Serial number: 00000000733068
    Coding: E5890F0600041800001400001400000000
    Shop #: WSC 00046 412 1548288
    VCID: 40A1B9FC13AD324289-8014
    Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
    Component: Wischer VW350 012 0401
    Coding: 00065493
    Shop #: WSC 00046
    Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
    Component: RegenLichtSens 005 0605
    Coding: 00217125
    Shop #: WSC 00046
    Address 15: Airbags Labels: 1K0-909-605.lbl
    Part No SW: 1K0 909 605 D HW: 1K0 909 605 D
    Component: 02 AIRBAG VW8 022 0600
    Revision: 05022000 Serial number: 0033JD0EZ2EH
    Coding: 0012338
    Shop #: WSC 00046 412 00000
    VCID: 2D7FF048B43FCF2A52-8078
    Subsystem 1 - Serial number: 6332MSME48056003
    Subsystem 2 - Serial number: 6342MSME49310504
    Subsystem 3 - Serial number: 6351HSME33035C02
    Subsystem 4 - Serial number: 6361HSME57177702
    Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
    Part No SW: 1K0 953 549 A HW: 1K0 953 549 A
    Component: Lenks‰ulenmodul 012 0030
    Coding: 0000042
    Shop #: WSC 00046 000 180189
    VCID: 3041E93CA30DA2C279-8064
    Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
    Part No: 1K0 920 961 B
    Component: KOMBIINSTRUMENT VDD 0814
    Coding: 0000403
    Shop #: WSC 00478 210 181999
    VCID: 2977045880D7D30ABE-807C
    Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
    Part No SW: 1K0 907 530 E HW: 1K0 907 951
    Component: Gateway H09 0110
    Revision: 09 Serial number: 27001046020110
    Coding: 3D0F0B40070001
    Shop #: WSC 00046 412 1957888
    Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
    Component: IMMO VDD 0814
    Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX2.lbl
    Part No: 1K0 959 701 L
    Component: Tuer-SG 024 2470
    Coding: 0000564
    VCID: 3753D220466375FA38-8062
    Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
    Part No: 1K2 909 144 G
    Component: EPS_ZFLS Kl.2 1301
    1 Fault Found:
    00778 - Steering Angle Sensor (G85)
    000 - -
    Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
    Part No: 1K0 959 433 BK
    Component: 01 KSG 0301
    Coding: 80F802087F2D8505485AC69010
    Shop #: WSC 00046 123 12345
    VCID: 7AD50B1435F1A89287-802E
    Subsystem 1 - Part No: 1K0 951 605 A
    Component: LIN BACKUP HORN H01 1201
    Subsystem 2 - Part No: 1K0 907 719
    Component: Neigungssensor 003 0003
    Subsystem 3 - Part No: 1K0 951 177
    Component: Innenraumueberw.004 0101
    1 Fault Found:
    01134 - Alarm Horn (H12)
    004 - No Signal/Communication
    Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
    Part No: 1K0 959 702 E
    Component: Tuersteuergeraet 09 0156
    Coding: 0000052
    VCID: 3147EC38A807ABCA76-8064
    Address 56: Radio Labels: 1K0-035-1xx-56.lbl
    Part No: 1K0 035 186 J
    Component: Radio GR0 0014
    Revision: 0001002S Serial number: VWZ2Z2D2000758
    Coding: 0040402
    Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
    Part No SW: 1K0 963 235 D HW: 1K0 963 235 D
    Component: PTC-Element 0404
    Revision: 00700000 Serial number:
    VCID: 2C79FD4C8F25C62245-8078
    1 Fault Found:
    00361 - Heater Element for Auxiliary Heater (Z35)
    014 - Defective
    End-------------------------(Elapsed Time: 01:03)--------------------------
  2. Re: Golf GT TDI 2.0 Crank, no start issue
    Dec 2014
    Bedford
    42 Post(s)
    Looks like a faulty crank sensor. Really crap to change. Recommend paying some poor bugger to change it. Have seen a few with wiring faults where the wiring has rubbed through around the gearbox. Wouldn't recommend fitting a cheap sensor either.
    Sent from my SM-G900F using Tapatalk
  3. Re: Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    Thanks for the reply! Now pretty certain it is the sensor - registering no engine speed on cranking when monitoring with VCDS - also now showing MIL on for the sensor in the error log.
    Is it many hours work for a garage to change? I only need the car for another month before travelling for 6 months so i'm trying to avoid any big expenses as want to change her when i get back
    Thanks again
  4. Re: Golf GT TDI 2.0 Crank, no start issue
    Dec 2014
    Bedford
    42 Post(s)
    Best way to change it is remove the charge air pipe and oil filter /oil cooler housing. Then access is reasonable. I reckon 2 or 3 hour's labour.
  5. Re: Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    Thanks for the advice, much appreciated! Will post the solution when I get it fixed!
  6. Re: Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    So after 4 weeks and a lot of money spent - i'm still no where closer and would really appreciate any further suggestions! Here is what I have done so far with no joy
    -New Crank sensor
    -New Cam sensor
    -Tested Replacement ECU
    -Replacement fuel filter
    -Removed injector wiring loom, cleaned and checked for continuity at all points
    Fuel pump is definitely priming and reaching the filter - could a tandem pump fault cause a no start? The engine feels like it almost catches but not quite.
    Thanks in advance!
  7. Re: Golf GT TDI 2.0 Crank, no start issue
    Dec 2014
    Bedford
    42 Post(s)
    I would of stopped after the new crank sensor. Any new fault code's? It's always hard to diagnose faults like this over the Internet. Could be broken wiring in the loom from g28. Pin 1 should be live to the sensor pin 3 is earth pin 2 is sensor voltage back to the ecu. Ideally check these at the ecu plugs and for continuity from the pin side back to the g28 plug. You don't want any more than 9 ohms in any of the wires. Another thing it could be is an injector. If one goes down it won't start. I would take the cover off and check resistance at the terminals of each injector and then check from each terminal individuly to the body of the injector if you get a reading here then you have found it. ...or an easier way to rule them out is disconnect no1 injector wiring plug at the injector then try and start it. ..if no joy then connect no1 back up and disconnect no2 injector no joy then re connect and repeat process for no3 and no4 .
  8. Re: Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    Unfortunately, I failed with the crank sensor job despite getting to a point where I could see it (bolt rusted and didn't want to round it out) so had to tow it to a garage. After changing crank sensor with no luck they did some scans and had both crank and cam sensor error so suggested engine timing hence the cam sensor (and a new belt but that's another story!!) . They did get it running after a bit of cranking and thought that was problem solved but back to square one when I went to collect and it wouldn't start. They had an electrical engineer look at it and he suggested loom or ECU.
    Wish I had stopped at crank sensor! Will test the injectors as described - appreciate it's a tricky one to diagnose so am grateful for the suggestions!
  9. Re: Golf GT TDI 2.0 Crank, no start issue
    Dec 2014
    Bedford
    42 Post(s)
    Injectors don't always show a fault and you can try it at no cost.
  10. Re: Golf GT TDI 2.0 Crank, no start issue
    Jan 2013
    Thanks for the advice! I'm going to be parking up the car for 5 months now and will revisit the troubleshooting when I get back - will be sure to try the injectors and advise of the solution! Cheers
  1. Replies: 3
    Last Post: 15-08-2016, 09:21 AM
  2. Replies: 3
  3. Please Help Mk 4 golf tdi 150 - Hot start issue
    By Jester27 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-02-2016, 05:34 PM
  4. Replies: 0
    Last Post: 07-12-2015, 04:17 PM
