Thread: Can't open door rear drivers side vw Passat estate 07
Results 1 to 8 of 8
  1. Can't open door rear drivers side vw Passat estate 07
    Mar 2012
    birmingham
    Can't open the rear driver side door from the outside ,I can open it from inside but not out ,I've tried slamming it shut see if the cable falls into place but it's not happening ,so I'm going to try and put the cable back in by hand but finding it difficult ,so far I've taken the door card off but struggling to remove the door plate ,I removed the window motor and outer screws which fix the large plate to the door but can't see what else i need to do any ideas
  2. Re: Can't open door rear drivers side vw Passat estate 07
    Sep 2008
    SE London
    Check that the Bowden cable ball end is in its clasp? The low temperature causes it to come out but just stay there when the lock's operated from the outside. There's an uprated Bowden cable available from VW spares. Attempts at spraying with WD40 won't completely fix as the Bowden cable gets stiff along its entire length leading to its ball-end coming out
  3. Re: Can't open door rear drivers side vw Passat estate 07
    Mar 2012
    birmingham
    I would if I could get to it,That my problem. I've removed the door card then the window motor and outer screws on the mechanism door plate but it still won't come off .i can see 3 plastic clips but don't want the break them not sure if they can be fixed back on
  4. Re: Can't open door rear drivers side vw Passat estate 07
    Mar 2012
    birmingham
    I've managed to take the plate off by drilling the rivets out but can't take the lock mechanism out to put the cable back in any ideas what todoIMG_4048.jpg
  5. Re: Can't open door rear drivers side vw Passat estate 07
    Sep 2008
    SE London
    Quote Originally Posted by scanny1 View Post
    I don't recognise your pix. But just remembered that I put together a help .doc with the URLs and other pix to do with driver's door including an exploded ETKA diagram. In case it ever happened to me. So PM me an email address for return attach. Hope it helps?
  6. Re: Can't open door rear drivers side vw Passat estate 07
    Mar 2012
    birmingham
    I've sent you my email address and appreciate if you can help .the photo i have shown on here is on its side that's probley why you don't recognise it.
  7. Re: Can't open door rear drivers side vw Passat estate 07
    Mar 2012
    birmingham
    Is there a way to remove lock as the window runner is in the way doesn't show in the manual
  8. Re: Can't open door rear drivers side vw Passat estate 07
    Apr 2007
    France
    12 Post(s)
    I'm sure this has been covered previously on here, right down to the last detail, but I'm not sure how best to search for it. Presumably you've tried?
    1996 Laguna 2.2D
    1977 MGB roadster
  1. Driver side rear door won't open from outside
    By apache24uk in forum Golf MK5 - 2004 - 2009
    Last Post: 02-03-2016, 11:19 AM
  2. Please Help Rear drivers side door won't open
    By AdFitz24 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-01-2016, 10:04 PM
  3. Attention Passat 'Sticking' / hard to open drivers door
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2011, 12:48 PM
  4. Please Help Drivers side door wont open?
    By moh4mmedali in forum Golf MK4 - 1999 - 2004
    Last Post: 24-02-2010, 08:47 PM
  5. Drivers side door wont open?
    By steeevo in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 03-02-2009, 03:37 PM
